Problem with Slave Cylinder Removal
Old Oct 14, 2018
98HondaLove's Avatar
98HondaLove is an unknown quantity at this point
So I got the slave out but the clutch hydralic line that connects to the top of it snapped off as i was trying to unthread it on my 2003 Honda civic. I then tried to just remove that part of the line from the other end but the nut wont budge. I will provide pictures and I'm not really sure what to do at this point any advice would be appreciated thank you.
-jay
Old Oct 14, 2018
Slumpertcivic's Avatar
Re: Problem with Slave Cylinder Removal
Yea I discovered that system was in very poor shape on my car too. The clutch uses brake fluid which is hydroscopiic so it sucks in water from the atmosphere. 15 yrs later and fittings and piston have internal rust damage and the fluid was as brown and thick as a chocolate milkshake.
You still might get lucky using a correct metric flare nut wrench. (They grab on 5 sides). Definately get the right wrench if you need to replace all way back to clutch master cylinder.
Old Oct 16, 2018
jaymorac's Avatar
jaymorac is an unknown quantity at this point
Just wanted to thank you for your reply. My buddy ended up coming over cutting the line heating up the nut freeing it lose and we got a new steel line with adapters for about 5$. Alls well as far as that goes but now Ive run into another issue with the system itself. Thanks again !
-Jay
Wankenstein
Nov 17, 2017 08:02 PM
jbeaman96
Feb 22, 2015 08:27 PM
civicnewb1988
Feb 12, 2011 05:06 PM
SleakCivic02
Aug 19, 2005 01:39 PM
maiden4ever
Jul 13, 2004 12:46 PM
