Drums--->Discs SPELLED OUT
Old Aug 5, 2008
  #181
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
Re: Drums--->Discs SPELLED OUT
i bought in person for 250$!!
just remember to get IS brake lines
Old Sep 4, 2008
  #182
turboyourcar's Avatar
turboyourcar is an unknown quantity at this point
Angry Re: Drums--->Discs SPELLED OUT
so is the only was to get the cam bolt out is with some pd blaster(WD 40) and the biggest hammer you can find or is there an easer way
Old Sep 4, 2008
  #183
Boilermaker1's Avatar
Jap-Euro Fusion
by and large.... the hammer method works best. over time and alignments they slip around and get stuck together. Its best to replace it once you get it out.
Old Sep 12, 2008
  #184
04 Honda Civic's Avatar
Just to clear things up as long as I have and ex (abs) I dont need a new proportioning valve? It will take care of itself? Also what year SI do I need these brakes off of I would like to get it off the newest year possible. I think 2003 is the last year with 4 lug? 2004 they started doing 5? Is this correct? If so are 02-and-03 exactly the same? like can I mix and match if need be?
Old Sep 13, 2008
  #185
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
everything has to be off an 02 or 03 civic si or 01-05 el. yes you can mix and match. a new ppv isnt required on any model. you dont really want to mess with the brake bias anyway unless you really know what your doing. if anything you would want a new brake mc. but the stock equipment is perfectly fine for the swap
Old Sep 13, 2008
  #186
The master cylinder is different then the SI one? How much would it effect the braking performance?
Old Sep 13, 2008
  #187
double post
Old Sep 13, 2008
  #188
metalviper's Avatar
yes well you would have more psi of fluid pressure when braking so im assuming it would help lower braking distance but im just using my stock lx mc so i couldnt honestly tell you
Old Sep 13, 2008
  #189
good stuff thanks for the info..now just to actually find the parts
Old Sep 16, 2008
  #190
"wheel sensors and all the bracketry" what is meant by bracketry and do I need the wheel sensors, or can I use the ones I already have?
Old Sep 17, 2008
  #191
metalviper's Avatar
its talking about the the abs sensor. if you have an ex you wil need the sensors off an si
Old Nov 9, 2008
  #192
WannaBFast's Avatar
Prowlin' with a Purpose
Pictures fixed 2/2/06
First you need to acquire a set of EP3 discs. EL discs for Canadians also will work. The more complete you can buy, the better, low miles is good too. If you build them, which I advise against because its expensive, you need knuckles, the hub and bearings, caliper assembly, wheel sensors and all the bracketry. Regardless, you need Si brake lines and EP3 or DC5 ebrake cables. I believe non abs cars will require a new proportioning valve although I can't confirm this. EX models don't need one, the ABS takes care of it.
Remove the stock wheel sensor from the drum. Its the oblong shaped thing in on the back that the orange plug is attached to. Remove the bolt then pry it out carefully. You'll need to do the same for the ones on the discs. Put the stock ones from the drums in the discs. Bolt them back in, toss the Si ones.
ok.. so if im reading this correctly, you need the abs sensor from the donor car... but why are you swapping the abs sensor from the drum to the disk knuckle?
Old Nov 12, 2008
  #193
metalviper's Avatar
you dont need the donors sensor, they wont correctly. you have to reuse the drum abs sensor
Old Nov 27, 2008
  #194
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
Hi...
Someone have news about the proportioning valve...
I made the swap 2 years ago and I still searching for a prop valve it gonna make a better job than the stock DX one...
Have some news about de master/booster upgrade ????
I have 12 inch Powerslot front disk convertion with OEM caliper... should I swap my booster/master for a RSX-S one ???
or may be RSX-Base or Civic Si ???
Old Feb 2, 2009
  #195
lordhelmet's Avatar
Can people weigh in with the pad life they are receiving after doing the swap?
Old Feb 2, 2009
  #196
metalviper's Avatar
a ppv will mess with the brake bias, y would you want to do that? if your brakes can still lock up theres no need for a bigger booster. pad life is dependent on the pad compound.
Old Feb 2, 2009
  #197
streetthrowback's Avatar
streetthrowback should not be trusted
hey boilermaker thanks for closing down my 1st thread
Old Feb 2, 2009
  #198
lordhelmet's Avatar
So what kind of pad life are you getting?
Old Apr 17, 2009
  #199
blissman20's Avatar
blissman20 is an unknown quantity at this point
This maybe a stupid question and I have read and tried to find info on this but can i get a set of from rotors and pads and mount them on the rears? or is that just completely and underlly stupid?
Old Apr 17, 2009
  #200
pon55's Avatar
^ ^ ^ Yea that
Old Apr 17, 2009
  #201
how would u attach the caliper? lol good try
Old Jun 7, 2009
  #202
dads5150civic's Avatar
dads5150civic is an unknown quantity at this point
Kick *** thread. I'm hoping to get the money together this summer for this conversion. It's already an EX with ABS, so, I'll just need to get my hands dirty.
With the exception of a few spelling challenged people with no concept of searching previous posts, I have been quite impressed with the amount of knowledge being throw around in these forums. Thanks guys.
Old Jun 7, 2009
  #203
pon55's Avatar
Du got sumptin aganist srellen chalenged peps?
(wats search?
Old Jun 8, 2009
  #204
(wats search?
Thanks Pon...that made me laugh!
Old Aug 2, 2009
  #205
mitch_poll's Avatar
mitch_poll is an unknown quantity at this point
if i only use knuckles can i put a big brake kit on it instead of stock rotors and calipers?
Old Nov 3, 2009
  #206
Pongo08's Avatar
Pongo08 is an unknown quantity at this point
i havent read through this thread completely, but does it have anything to do with swapping drums for disks? cause thats what i wanna do.
Old Nov 3, 2009
  #207
Pongo08's Avatar
ok, nvm on my previous post. man do i feel stupid!!
Old Nov 3, 2009
  #208
pon55's Avatar
Old Nov 7, 2009
  #209
codehunter447's Avatar
codehunter447 is an unknown quantity at this point
:d lol :d
Old Nov 7, 2009
  #210
OK that's weird I just tried to post a message with the green grinning smiley and it just shows up as this :d
How come it does show up as the smiley?
