Drums--->Discs SPELLED OUT
Old Apr 19, 2006
  #91
Bojangles80's Avatar
Bojangles80 is an unknown quantity at this point
Yeah if anyone knows of a way to overcome the proportioning valve issue in the LX model please let me know... that's the only thing that I'm concerned about.
Eyger did it end up working in your car? If so what did the slave assembly end up costing you?
Old Apr 19, 2006
  #92
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Sorry hommie, I havn't done it yet (me = poor bastada). But you bet I'll share everything when It's done in the future.
Old Apr 19, 2006
  #93
skipbarber's Avatar
i have a dx, i didnt change the proportioning, everything works fine, and i still had a very significant improvement in stopping performance. k, thnx.
Old Apr 20, 2006
  #94
Eyger's Avatar
Right, you can just leave it. But I believe that in order to obtain optimum performance out of the rotors, you would have to change the master slave and proportioning assembly. So I guess you could say from stock to good, or from stock to really good.
Old Apr 21, 2006
  #95
skipbarber's Avatar
i was quoted about $400 to have custom proportioning done, and quite honestly, the difference probably isnt worth the money. I feel that the $200 i paid for my conversion has more than satisfied my performance expectations.
Old Apr 21, 2006
  #96
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
Just trying to clear things up here,
to do this you need the stock Si rear disc's and calipers + e-brake cables. To "build them" meaning changing rotors and calipers? i need more things?
Im planning on keeping the stock calipers but changing rotors, what exact items do i need before i go buying all of this stuff?
Old Apr 25, 2006
  #97
goodtimes's Avatar
i put mine on today WOOT pics up a little later
Old Apr 29, 2006
  #98
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
damn i want to do the swap but i'm scare i might *** up! brakes and suspension is sooo important...i know how to change my own brakes, so you think thats a good enough skill to do this swap?
Old Apr 29, 2006
  #99
K20me's Avatar
Yes. You will need a friend to help you with bleeding though.
Old Apr 29, 2006
  #100
CIVIC X3's Avatar
i've bleed the brakes before but never have i flush it. its bcuz i dont know how. any tip?
Old May 8, 2006
  #101
racoon_assasin's Avatar
racoon_assasin is an unknown quantity at this point
Just out of curiosity....
Okay, so, just to make sure ... are the rotors the same diameter as the stock EX rotors? My two concerns with doing this conversion was A) the 5-lug mistery (which I can see now is not a problem as long as it's from the EP3) and B) I like to take my rims off in the winter and throw my stock 15's on w/ winter tires....so...if the set-up won't fit in 15's....I can't do this. Thanks for the input.
Old May 8, 2006
  #102
goodtimes's Avatar
well ok the rear are a little bit smaller than the front
A) 01-03 were 4 lugs i belive
B) They will clear the 15's no problem
Old May 11, 2006
  #103
Boilermaker1's Avatar
Jap-Euro Fusion
4 lug EP3 rotors are the same
A) is wrong, it is a problem to just go 5 lug, search for that, no sense clogging this thread
B) use 4 lug brakes.
Old Aug 13, 2006
  #104
sspem2's Avatar
em2
lets say i get the knuckles, etc, etc. could i use lets say civic SI brembo rotors and pads so ill have a big brake kit in the back to match the front? so i would use civic EX which is my car brembo rotors and pads and civic SI brembo rotors and pads for the rear with the knuckles, etc. would that work?
Old Aug 25, 2006
  #105
icetrap's Avatar
icetrap is an unknown quantity at this point
Originally Posted by eugthebear
hey guys would a 3rd gen tegs rear brakes work too?
Yes you can fit EK series onto our cars. They are 242mm, smaller rotors
Old Oct 17, 2006
  #106
ryangt's Avatar
ryangt is an unknown quantity at this point
can i use rsx rear brakes on my 01 ex? A buddy of mine has fronts and rears for 500.
Old Oct 17, 2006
  #107
robbclark1's Avatar
Retired suspension supermod.
yes, but you will need a new ball joint and LCA for the front and maybe the whole rear LCA.
Old Oct 17, 2006
  #108
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
is honda the only place to get rsx e-brake cables?
Old Oct 17, 2006
  #109
ryangt's Avatar
rsx rears
I have the complete rear control arms for the rsx with everything attatched, calipers, rotors, knuckles yadda yadda, im not very worried about the fronts untilll i go K20
SO the rear LCA should bolt right up correct? And everything from there is pretty much bolt on.
Then that brings me to the e brake cables, will i be able to get away with using the RSX ones? or my own?
Old Oct 17, 2006
  #110
rice4lyfe's Avatar
yes, the rsx, 1.7el and the sir e-brake cables will work with the swap.
Old Nov 6, 2006
  #111
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
What about 03 Si rear discs on the back of my 04 ex? I would think it would all match up, but am not sure. I do know that the 04 Si has FIVE LUG . . . so I'm kind of screwed there.
Old Nov 6, 2006
  #112
goodtimes's Avatar
yes the 03 rear discs will fit with no problem b/c there 4lug
Old Nov 6, 2006
  #113
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Question
Can anyone tell me the wrench/socket size the cam nut is? Does the nut come off or the bolt? I measured the width to be .955" and it turns out to be 24.257mm.
Old Nov 7, 2006
  #114
NICE! Thanks a bundle, now I need to call some junkyards, lol.
Old Nov 7, 2006
  #115
I brought my good calipers home from work and measured it again; It's 24mm, bigger than any socket or wrench I have right now. Keep this in mind when you guys go to the junkyard to get your EP3 knuckles.
Oh yea, the socket will have to be at least 40mm deep.
Old Nov 7, 2006
  #116
rice4lyfe's Avatar
at least you're not changing your LCA, you need specialty tool to get that out from honda.
btw, anyone have one?
Old Nov 28, 2006
  #117
AMontalvo22's Avatar
AMontalvo22 is an unknown quantity at this point
What is an EP3? I'd like to do this install on my 02 EX. What do I need to get? and where?
Old Nov 28, 2006
  #118
ep3 is a civic si hatchback.. check the frist post for all the things you need.. if you look hard enough you can prolly find someone selling a setup in the forsale thread. if you cant find one and you have the cash, i'm sure you can get the setup at www.hondaautomotiveparts.com
i'm not 100% sure, but i think you can use a setup from a canadian acura 1.7EL..
Old Nov 28, 2006
  #119
pon55's Avatar
What happened to your for sale thead?
Sorry for the OT reply
Old Nov 28, 2006
  #120
lol.. i just kinda abandoned it.. no one seemed to want any of it.. i may just ebay it all whenever i get the time.. either that or i'll be able to sell it easier when i'm able to get my own place up here in washington, but that wont be til after i come back from deployment
