Sponsored by:
Sponsored by: CARiD
Can someone tell me what part this is??
Old Jun 18, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question Can someone tell me what part this is??
I was taking apart the steering column today and a piece of something fell out. Looks like it was from the old steering wheel assembly or something. I have an aftermarket wheel now. I didn't put it in so I am thinking they left this in here. Anyone know what piece this is, or where it comes off of?
Link
AND
Link2
Old Jun 18, 2003
RiceBuRNeR's Avatar
Turbo Member
Looks like it was part of the clock spring mechanism that helps the wheel return to center.
heres the pics
Old Jun 19, 2003
Sivion's Avatar
Resident Tough Guy
Exclamation Actually..
I think I just discovered what it was. It was the part that went on the stock steering wheel that clicked the turn signal off when the wheel is turned one way or the other. There are little tabs on the side of the part which would indicate that it would hit the lever. So it makes sense now because when I turn, the signal stays on unless I switch it off.
Old Jun 19, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
that sucks
Old Jun 19, 2003
Bartkat's Avatar
That makes sense. Glad you figured that out. I couldn't find it in the diagrams.
Old Jun 19, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
i'd go back to the person who installed the wheel and ask them why it's not installed. maybe it didn't fit with the new wheel, but the new one should have come with a replacement piece for that purpose. they should then install it so your signal works right.
Old Jun 19, 2003
Bartkat's Avatar
I think he did it himself.
Old Jun 19, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Re: Actually..
Yup, that's what that is. I've had to replace them in other cars that I owned, they wear out and don't work after a while. It should go between the wheel hub and the back of the wheel. If it wasn't installed, there's a good chance that it doesn't fit with your new wheel. But I would take it back and ask the guy who did it first. If it does fit, he has to take the hub adapter off and install that, then put the adapter back on, then install the wheel again.
Or you could leave it off, and drive around like all the elderly drivers around here. They drive for blocks with their signal light flashing, indicating that sometime later that day, they will eventually be turning left or right, eventually.
Old Jun 19, 2003
Bartkat's Avatar
I hate when people do that.
Especially when they finally turn they go the opposite way.
Old Jun 19, 2003
RiceBuRNeR's Avatar
Turbo Member
Doh....I hate it when Im wrong.
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
