this is a very stupid question
I tried installing my GC coilovers today and they didn't go on too well, so my question is, are the bigger ones for in the front or in the rear, I tried the big ones up front and it didn't fit...am I wrong??
thank you for the replys, I just have one more question.
The smaller springs go in the front along with the longer thread right? and the shorter thread goes in the rear with the bigger springs?
I think this is the right way
here are the measurements i took off my fronts when i had them apart. I posted this in Jan. to help someone else out. Please be aware that this is the kit for 2001 2dr
"ok look on the inside of the sleeves the ones with the BIGGEST notch on the inside are the rears. Since I just happened to be installing my front koni shocks right now I will give you the measurements on the fronts the front spring is a little less than 6" the sleeve is about 41/2" tall. In the front you should have an aluminum upper spring seat a rubber o ring which keeps things from rattling. the rear should have an upper urethane spring seat/insert and a urethane sleeve that is split.. I think that is it i'm going by memory on the rear stuff. hope this helps"
NoobyKid
Jul 13, 2015 07:53 AM
