this is a very stupid question
Old Jun 11, 2003
BIG's Avatar
BIG
Exclamation this is a very stupid question
I tried installing my GC coilovers today and they didn't go on too well, so my question is, are the bigger ones for in the front or in the rear, I tried the big ones up front and it didn't fit...am I wrong??
Old Jun 11, 2003
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
what yrs is your car. You may have the wrong yrs of GC on your car. GC made differen't coilover for differen't yrs
Old Jun 11, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
http://www.7thgencivic.com/modules.p...howpage&pid=56
Old Jun 11, 2003
Weaponx12o's Avatar
arent ground control coilovers supposed to be the same size for all 4?
Old Jun 12, 2003
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
You damn right it's a stupid question... J/K I thought that coil overs for our cars are the same size. I know my Skunk 2 are the same size for all 4
Old Jun 12, 2003
VTECnique's Avatar
VTECnique is an unknown quantity at this point
should be same size for all 4. check the year of the GCs
Old Jun 12, 2003
cdmx's Avatar
why dont you compare them to the stock springs...bigger springs go in the front and the smaller ones in the rear
Old Jun 13, 2003
VTECnique's Avatar
that too... but i think all the versions of the GCs for the 2001+ civics are the same size all around
Old Jun 13, 2003
BIG's Avatar
BIG
thank you for the replys, I just have one more question.
The smaller springs go in the front along with the longer thread right? and the shorter thread goes in the rear with the bigger springs?
I think this is the right way
Old Jun 13, 2003
djmota's Avatar
here are the measurements i took off my fronts when i had them apart. I posted this in Jan. to help someone else out. Please be aware that this is the kit for 2001 2dr
"ok look on the inside of the sleeves the ones with the BIGGEST notch on the inside are the rears. Since I just happened to be installing my front koni shocks right now I will give you the measurements on the fronts the front spring is a little less than 6" the sleeve is about 41/2" tall. In the front you should have an aluminum upper spring seat a rubber o ring which keeps things from rattling. the rear should have an upper urethane spring seat/insert and a urethane sleeve that is split.. I think that is it i'm going by memory on the rear stuff. hope this helps"
Old Jun 13, 2003
BIG's Avatar
BIG
I will try that, thanks man, still looking for second opinions though (no offence bro) haha
cheers
Old Jun 14, 2003
BIG's Avatar
BIG
so large thread with small spring in front, and small thread with big spring in rear??
anyone??
alaga
Feb 28, 2016 02:19 PM
EdGasket
40
Nov 27, 2015 11:11 AM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
NoobyKid
Jul 13, 2015 07:53 AM
