Lower tie bar
Old Jun 7, 2003
marmail's Avatar
marmail is an unknown quantity at this point
Lower tie bar
I just bought a front DC strut bar and I noticed a diffenace in going into turns if I b uy a lower tie bar will i notice a change or is it more for looks.I dont plan on getting an upper
Old Jun 7, 2003
robbclark1's Avatar
Retired suspension supermod.
a tie bar is not a performance part. It helps to brace the chassis if you upgrade your sway bar. In the older civics, if you put a large sway bar on the rear the chassis could break so in order to prevent that they made tie bars.
Old Jun 7, 2003
AlpineWhiteM3's Avatar
AlpineWhiteM3 is an unknown quantity at this point
Like robbclark said, it stiffens the chasis...you can't feel it.
Buy one only if you have an rsx-s antisway bar, or else it's just there for looks.
Old Jun 7, 2003
robbclark1's Avatar
well they make thicker bars than 19mm. The 19mm probably won't crack your chassis, but anything 20mm and above might. That is why the progress 22mm sway bar comes with an integrated tie bar.
Old Jun 7, 2003
marmail's Avatar
Thank you
Old Jun 7, 2003
Weaponx12o's Avatar
make sure if you get anything over 19mm, you get a matching front sway bar with it. if you only have a rear sway bar thats 22mm you will understeer.
Old Jun 8, 2003
What front antisway bars are out there for this civic? The stock is 25.9 or 29.4 mm...forgot
pretty darn good though!
Old Jun 8, 2003
Weaponx12o's Avatar
i dont think the stock front sway bars are that thick. i think its more around 17mm. progress sells front and rear sway bars, and i think neuspeed does too
Old Jun 9, 2003
Bellz's Avatar
A quick search in this Suspension Forum reveals a DIY by Grey (who else?) on mounting a front sway bar. Click here for linkage.
And to answer the size question, read the following quote from the DIY:
"The Progress sway bar is 27mm in diameter and weighs 15 pounds while the stock sway bar is 25.4mm in diameter and weighs 7 pounds."
Old Jun 9, 2003
robbclark1's Avatar
yes Bellz is right about the stock front sway bar, but you usually don't need a front tie bar if you upgrade your front sway bar.
Old Jun 9, 2003
tekgnosis's Avatar
Ask me about your mom.
yup, you don't NEED a front tie bar...but the neuspeed X-Brace is something to buy!!!
Old Jun 9, 2003
Zzyzx's Avatar
Autocross Junky
Actually its the opposite, larger rear bar will reduce understeer/increace oversteer.
Old Jun 9, 2003
Zzyzx's Avatar
Autocross Junky
this probably means that the stock bar is hollow while the Progress bar is solid.
this also means that the Progress bar is MUCH stiffer then stock. (when calculating strength of a anti-roll bar, If that bar is hollow, you must subtract the hollow portion out of the equation, thus makeing a hollow bar Vs a solid bar of the same diamiter weaker) there are other vairiables, such as lenght of the bars conecting arm (longer = weaker) ect...
Old Jun 9, 2003
artychris's Avatar
artychris is an unknown quantity at this point
the lower rear tie is all show
I have the 19mm RSX bar and I also got the DC Sports Lower Rear Tie in polished.
The peoople driving behind love the look especially next to the Apexi WS exhaust.
I'd get that piece combined with the 19mm RSX for a nice neutral ride
Old Jun 9, 2003
flotsamm's Avatar
So now I'm curious, is this Civic brochure from Honda's website wrong? It says the stock swaybars are 15.9 for the front and 12mm for the rear.. ???
Dave Brabant
20
Oct 6, 2015 12:44 AM
Sep 27, 2015 11:33 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
beantech
Sep 6, 2015 01:46 AM
Viczhou
Sep 2, 2015 07:55 PM
