Problem w/ Clearing Headlights
Old May 25, 2003
salokod's Avatar
salokod is an unknown quantity at this point
We have them apart, but the 2 screws we need to take out are weird.
it says use philips, but it's 6 sided....
and there's a little stud in the middle so we can't put anything far in there...
what to do!!!
Old May 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
hex key.
This thing:
Old May 25, 2003
civicvtec1ps's Avatar
Search and Learn
Originally posted by ak
hex key.
This thing:
haha there you go.
Old May 25, 2003
flotsamm's Avatar
Torx maybe? I havent cleared my lights but it solds like a torx head..
Old May 25, 2003
synikal's Avatar
synikal is an unknown quantity at this point
I believe the 2001 civic has phillips. I have a 2002 and it was torx. You might be able to get an allen wrench to fit, but I had a torx driver for cell phones and it fit perfect, so thats what I used.
Old May 25, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
I ran into same problem, if you dont want to run to the store , just use a pair of vise grips and turn it in the same direction as you would with a screw driver. I had the same problem when I cleared my friends 2002 2 door. Post pics when you get them all done =)
Jeff
Old May 25, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
I used what ak said!
Old May 25, 2003
slystad810's Avatar
Yeah it's a Torx...
Old May 25, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
you can either go and buy a torx set, or use a very tiny screw driver and wedge it in the head of the screw....which ever is cheaper is what i say
and the screws are diff. on 01 and 02 mod.
Old May 26, 2003
Diablo's Avatar
Diablo is an unknown quantity at this point
I just ran into the same prblem on my 03 EX
Old May 26, 2003
Diablo's Avatar
my camara is kinda shity so i hope you could see what screw he is talking about. by the way a visegrip worked just fine.
Old May 26, 2003
branden's Avatar
branden is an unknown quantity at this point
use some pliers or visegrips
Old May 26, 2003
Entropy's Avatar
Entropy is an unknown quantity at this point
i had that problem with my 2002 ex, i took the lights to a pep boys and a guy behind the counter let me take a screw driver with that torx bit in it out to my car and i cleared them out there, took me like 5 minutes to do in a friends car, then gave the screwdriver back and went home to install'm
Old May 26, 2003
I cleared my sedan lights a while back and everything was much easier to do. The glue softens in the oven, and the inside is no problem to take apart. Don't know why people say the coupe is easier.
Old May 26, 2003
reytito's Avatar
in my 03, i got the right ones off fine. for the left ones...i the star screw was stripping and it wasn't comin off. so i broke the tabs holding the amber peice in place, and shimmied the peice out of its compartment, and took it out of the headlight assembly via the headlight hole. do it VERY carefully, you could scratch the chrome.
Old May 26, 2003
tripledoublegs's Avatar
Euro-Spec
I don't think it's easier. Same headlights right??
Old May 26, 2003
Search and Learn
same headlights. but uses different glue. differnt plugs for bulbs( size wise)
Old May 26, 2003
Diablo's Avatar
Yeah the glue is much softer on my 03 than my 01
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Aug 25, 2015 10:47 AM
