S/T Sway Bar Kit is out and in stock!
Old May 21, 2003
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Talking S/T Sway Bar Kit is out and in stock!
These just came in last night..
S/T Sway Bars for 01-up Civic
This is for the FRONT and REAR! I have 3 sets in stock.
Old May 21, 2003
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
Do you know how thick these bars are? Are they like the progress 27mm-front & 22mm-rear? Does this come with a integrated tie bar in the rear also? Thanks
Old May 21, 2003
Zzyzx's Avatar
Autocross Junky
Are they Adjustible?
Old May 21, 2003
robbclark1's Avatar
Retired suspension supermod.
According to modacar, they are adjustable and come with an integrated tie bar. It isn't their regular kit, but the speedtech kit.
http://www.modacar.com/products/Honda/Civic/MODASWB/
Old May 21, 2003
Talking
Info: Suspension Techniques Sway Bar Kit (Front 1" & Rear 15/16") For Honda Civic 01-UP (COUPE & 4 DOOR)
Old May 21, 2003
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
r u gonna do a broup buy soon
Old May 21, 2003
TOOLOWCIVIC's Avatar
They look nice.
Old May 21, 2003
Zzyzx's Avatar
Autocross Junky
I just looked it over, and the endlinks and the tie brace may be adjustible, but thats not the same thing as the bar being adjustible. So to me thats not what im looking for.
However, the Comtech Sway/tie bar combo listed there for the 03 SI, appears to be. Those parts fit the civic coupe right? But at 535 thats a littel expesive to me.
Old May 21, 2003
robbclark1's Avatar
The comtech bar is way to expensive. Do you really need it to be adjustable? What is the benefit?
Old May 21, 2003
Zzyzx's Avatar
Autocross Junky
I autocross, and having an adjustable bar would allow me to Fine tune my handling. With a Standard Anti-roll bar you are stuck with one spring rate. Its better then stock, but you can’t adjust it to work with your other parts better. With an adjustable anti-roll bar, the bar can be adjusted to better work with your springs. For Example, if you were to have High rated springs, and your car still understeered, you could put on a larger Rear anti-roll bar to fix the problem. But what if by doing so, the car now oversteered. If the Anti-roll bar is not adjustable, then you’re screwed, but if it is then you can adjust the bar to work with those springs to make the cars handling Neutral.
For normal street applications a non-adjustable bar is perfectly fine. In motorsports you need that adjustability to tune the cars handling to the max.
Old May 21, 2003
robbclark1's Avatar
Ok, thanks. I plan on getting into Autocross. In fact, I am going to my first race on June 8.
I like making my car handle better, but I don't want to sacrifice too much of my ride quality because it is a daily driver. Maybe when I can make it a real race car and have another daily driver (and i can afford it) i will hopefully add better race parts
I have learned alot from you. Thanks
Old May 21, 2003
Zzyzx's Avatar
Autocross Junky
Have fun at your first Autocross, and remember Keep the shiny side up!
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
jessepimpride
Nov 13, 2001 05:59 PM
