Help w/ Voltmeter Install
Old May 16, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
Question Help w/ Voltmeter Install
im working on the install of my autometer voltmeter... the instructions say to use 18 gauge wire but all radio shack had was 12 gauge, so my question is would the 12 gauge be fine. im far from an expert on electrical type stuff. last question... i know you can use the gauge to monitor any 12 volt power source, so by hooking the gauge up to the + terminal on my battery, I would be able to monitor its output correct? one last question, seriously, the instructions also say to hook the light on the gauge up to the dash light wire... meaning to tap into that wire and splice the gauge light wire to it, correct again? thanks in advance.
Old May 16, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
with wire guages, the bigger the guage, the smaller the cable, so goin smaller guage is never a bad idea hooking the guage to any positive line in the car will give u a pretty close reading to what the voltage is across the terminals, the voltage loss is minimal if any at all. the best way to hook up the light wire is to use a t-tap. there worth there weight in gold, radio shack sells them
Old May 16, 2003
7thgen Man-gina
thanks for the help
Old Apr 22, 2004
deftones69er's Avatar
deftones69er is an unknown quantity at this point
i hooked the light up to my cig lighter i used a splicer its blue and i got my volts gauge and oil psi machanical light hooked there. the light stays on all the time but the bulb will not burn out. and its easy.
Old Apr 22, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
t taps are awesome
Old Apr 22, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
For the lighting you can also tap into the instrument cluster wire harness. This way your gauge dims with your regular gauge dimmer....
Old Apr 23, 2004
Yeah, tap an ignition controled wire for the actual voltmeter, and the illumination wire for the light. That way the light only comes on when you turn the car lights on. The wire is somewhere in that indiglo gauge diy here.
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
EM_WON
Jul 22, 2015 06:49 PM
