To the people who have installed Revo, OBX.....HELP!
ok, I popped out the clip on the primary shift linkage and got that out fine. But, on the SECONDARY one there is that plastic peice. Now, I dont know if there is some sort of clip or something?, if I just have to use force and pull out to the side?, or if you turn it somehow?? I ask cuz I dont want to break it. I am in the process right now, so a quick response would be very helpful..thank you.
ps. yes I did search every diy on the site.....its kinda vague about it. It just says pop out the clip and take the linkages out.
Edit: oh yea I have an 02 coupe if there is a difference in them
there should be a little tab that u use to rotate that section out of the shifter base. carefull because the base is made of nylon and will deform if you try prying to hard... hit this back if you need more nfo
Schneiderman
May 24, 2015 01:14 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
