2 Subs Better Than 1 Sub?
Old May 1, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, after I got my new JL Component set, I realized that one sub really doesn't sound as loud when the component set goes louder. I liked my JL 12w3 sub for a while, but it doesn't really even seem to hit as hard anymore, its probably just me. I currently have it in a custom ported box that is around 1.75 cubic cm, recommended specs. I am thinking of getting another 12w3 and I am looking for sub boxes. I am thinking of going with a closed box this time for dual subs, that has 1.00 cubic cm for each sub. Both are divided so each has its own chamber. If I use my Alpine M300 and wire each sub up seperataly and then connect both subs to the +/- terminals on the M300, will it be alot louder than my current setup?
Old May 1, 2003
WhiteRabbit's Avatar
should be
Old May 2, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
I would get another M300....300 watts to split really isnt enough to let those subs come alive. They are rated at 300 each....
Old May 2, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
The general rule for spl is this: If you double the surface area you normaly gain 3 dB. If you double your power you also gain 3 dB.
So if you add another sub and hook it up to the amp you have, which is a mono block amp and the power doubles when dropping it to 2 ohms, you should get about another 6 dB.
But now you are also going from a ported enclosure to a sealed so you may loose a couple dB also.
Its hard to say for sure on how much you will gain but it will definatly be louder.
Old May 2, 2003
ZSKCivic01's Avatar
Extreme Member
The thing though is that ill have two 12w3-D4 subs and I will have to wire them in parallel to get them at a stable 4Ohm load,which has an ouput of 150w x 1. If I wire two subs in parallel, then they will be handling a 1Ohm load and I don't think that my amplifier is stable at 1Ohm. So basically what im asking here is that ill probably have to wire both subs in parallel. Is it worth getting another sub using my mono sub amplifier? I can't afford another amplifier, I have just enough money for another W3 and a box. Also, should I go ahead and get a ported box or should I get a closed box for two W3 subs?
Old May 2, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
One alpine m300 wont be enough power to effectivly power two 12w3s. I would save enough money to buy another sub and another amp.
Old May 2, 2003
VNlilMAN's Avatar
The Standard One
kinda off topic but ya i should have gotten two punch hx2s rather then 1 power hx2
Old May 3, 2003
custom2k1's Avatar
Oh my bad, didn't know they were 4 ohm dvc's. Save and get another amp then.
Old May 3, 2003
AntDeezy's Avatar
this is why i dont hook my own shiet up anymore - i just go in say what i want and then the amazing part is I can just leave and when i come back its all done.... its like making wishes and having them granted - i just wish it was free......
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
sf3r8z
Sep 23, 2015 03:26 PM
redcloud
Sep 7, 2015 01:45 PM
