anyone know how to tamper with the signal bulb?
i got these oem signal bulbs from honda, i only want them to be on when i signal, anyone know how to do it?
k guys, just did a lil research. sum said 7440 bulbs and they will only go on when i signal, and sum said using electrical tape for one of the wires. not sure which one works, let me know any of u guys tried it. i prefer the electrical tape method cause my friend gave me some 7440 bulbs and it didn't fit into the socket
Some 7440 bulbs fit with no problem and others need to be adjusted. Generally you just have to shave off the little nubs near the base and they fit fine. Thats the best way to go.
For 7443, yes... just bend and cut one metal connector on each side. If you do this though, they will only come on when you signal, but also you will now have hyperblinkers. Not sure how to get around that, if have don't want hyperblinkers.
wat do u mean bent and cut each side, is that mean bent both sides and cut them or just one side and cut that side, possible to have a pic and show me? heh dont wanna mess up u know, i have no problem with hyper blink as long as its legal
If u only want lites to go on when u signal, u need to get the single filament bulbs. If u get double, they will go on with the parking lite as well as when u signal to turn.
Retired - SoCal FI Mod
look on the housing... there are 3 wires... 2 wires that power either the signal blinking or the parking lights... now.. if you have a test light, check to see which wire is the one powers the light that's always on... cut that wire and cap the end of it.... simple...
i just taped around the two middle wires of my 7443 bulb...worked fine for me..no hyperblinking..then again i modded my turn signal relay to be an adjustable hyperblinker...but i have it set to a pretty much stock rate
Civicforums Junkie
for what your trying to accomplish...yes...the lead on the left-side of each side is the 5W (thats the parking lead)
i cant link it for some reason...
'search' under 'tech-stuff' for 'HYPERBLINKER'
tried didn't work, need help.
k so when i look at the flament, goes one on the other side, one on this side, one on the other side, one on this side.
0=other side
T=this side
O T O T
i tried cutting the last two, O T and it iddn't work.
i tried cutting the two O, didn't work
0=other side
T=this side
O T O T
Civicforums Junkie
if you just want the signal to work and not the parking nor have a 'hyperblinker'...
then cut the left lead on each side of the 7443 and then reinsert the bulb into the socket...that will cut the 5W lead out of the system which would in turn make that a 'single-filament bulb'
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
meicalnissyen
Sep 25, 2015 12:12 AM
MamaBear2015
Sep 4, 2015 09:04 PM
