Skunk2 Question
Old Apr 15, 2003
BlueBoyCivic's Avatar
"Stage7"
Question Skunk2 Question
I know Skunk2's have been talked about b4, but I heard that they were supposingly pretty expensive. Well I just wondering...are these coil overs good or what? Because these here are not that expensive!!!
Are These Good?
Old Apr 15, 2003
robbclark1's Avatar
Retired suspension supermod.
Skunk2s aren't true coilovers, they are sleeved coilovers which means they don't have an integrated schocks. Usually sleeved coilovers run between $200-$300. Ground control and skunk2 probably are two of the best sleeved coilovers for the 7thgen and will run you about $300. You will probably need new shocks eventually.
Old Apr 15, 2003
"Stage7"
If I were to put these on, how long from the time of install will I need to get some new shocks? Thanks for all the info robclark1...
Old Apr 15, 2003
robbclark1's Avatar
It depends on a few things, your driving style, how far you lower, and the roads around your house. You could only lower 1" and have nice roads and not push the car. In that case, your shocks will last just as long as normal. Or you could slam it, drive it hard, and hit lots of pot holes/bumps. In that case, they will probably blow really quickly. all I can say is, it depends. If you plan on lowering more than 1.5" than they probably won't last more than a year. tons of people drive on stock shocks while lowering, but you take the risk of having your shocks blow. And right now the only option you have for shocks are the konis.
Old Apr 15, 2003
"Stage7"
Yeah, I'm prolly gonna be droppin it at least 2" So I guess I'll have to plan to get some shocks. And "Konis" What site can I find these at, at a good deal?
Old Apr 15, 2003
robbclark1's Avatar
Ask Rob from tornactive. Other than that, check the parts section. You know that they are just inserts and not full replacement shocks right? You will have to modify your front struts to make them fit. Besides if you are going to get skunk2's and konis that will cost ya around $900, you might as well as get true coilovers. Just my opinion.
Old Apr 15, 2003
Weaponx12o's Avatar
you might as well get true coilovers since you're going to have to buy shocks anyway. not unless you want your stock shocks to blow
Old Apr 15, 2003
DizWikedCivic's Avatar
were not rich as you ron, we cant afford true coilover, when you get your skunk2 slammed that ****
Old Apr 15, 2003
RoadRunner's Avatar
well i dont like sleeved coil overs, i have progress springs now and i plan on savin up enough to get true ground controls sometime this summer
Old Apr 16, 2003
robbclark1's Avatar
I didn't realize ground control made full coilovers four the new civic? They only make sleeved coilovers from what I know. They wouldn't be a good buy if you don't like sleeved coilovers.
junkyardguy
Sep 2, 2015 06:07 PM
naokigoffi
Aug 30, 2015 06:19 PM
S1N7H3T1C
Aug 28, 2015 01:00 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
