Rear brake conversion
Old Apr 9, 2003
RedDragon333's Avatar
I was talking witha friend of mine and contemplating converting my rear EX drums to disc brakes and going with AEM brake rotor upgrade to match my front set. What would this entail besides the obvious parts and brake line extensions? I was thinking about trying to buy the rear discs for the 02 SI and going from there rather than tracking down a rear OEM set. INFO would help guys
Old Apr 9, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Not sure if this is totally possible, but it might... if you found a wrecked Si... you could probably take the entire lower rear arm assembly including the hubs and brakes, bolt it right on, hook the lines up and go. Otherwise you'll need the hubs, spindles, caliper assemblies and some other bits to make it all work.
Going from scratch, I don't know. You might want to e-mail AEM and ask for the instruction sheet for the 6th gen conversion... they're pretty good about sending directions if you ask for them. The process should be pretty much the same.
Old Apr 9, 2003
anibal's Avatar
anibal is an unknown quantity at this point
I don't think the susupension components of the 6th gen Si will bolt on, the suspension geometry it's different....but who knows, must check it.
Old Apr 9, 2003
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
I dont think Boiler meant the components...just the general instructions should be pretty similar.
Old Apr 9, 2003
Looks like its time to do some research. Anyone that has any info that might help it would be greatly appreciated
7thgensurvivor
38
Aug 29, 2015 11:50 AM
MamaBear2015
Jun 11, 2015 07:33 PM
Broadbeb
May 14, 2015 09:49 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
Andy
Dec 29, 2001 07:32 AM
