Attn lowered civics
Old Feb 21, 2003
renagadecivic's Avatar
renagadecivic is an unknown quantity at this point
Attn lowered civics
How do you drive over speed bumps with low to the ground civics? I want to lower my civic but there is a lot of speed bumps in my area and I dont know what to do about that. I need help thanx.
Old Feb 21, 2003
GoOkStA's Avatar
GoOkStA is an unknown quantity at this point
go really slow, and u wanna go over them in an angle, or if it has a break in it, u can have one tire on and one tire off, but majority of time just go sideways
Old Feb 21, 2003
XoULaBeAT's Avatar
XoULaBeAT is an unknown quantity at this point
is there any headlight adjusting involved as well? esp when u lowered ur car.. (mine's stock so yea)
Old Feb 21, 2003
GoOkStA's Avatar
its up to u if u want to change ur headlight adjustment, it ur preference on how much of the ground u want to see
Old Feb 21, 2003
Royando's Avatar
Royando is an unknown quantity at this point
try the speedbumps in Mexico. my nephew took his 96 civic down there, lowered 2.5 inches..and those things are huge, no wonder why mexicans(im a mexican too by the way)can jump over the border so easily, thats cuz they been trained well..but yeah..
Sideways is always the key, and really really slow
Old Feb 21, 2003
Gryphin's Avatar
00 Hatchback Owner
or you go around [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 22, 2003
CivicGoh's Avatar
CivicGoh is an unknown quantity at this point
Well this is my set up i have skunk2 coilovers and koni yellows, you can get coilovers and have the height adjusted to ur taste, mine has about a sports drop (1.75-1.8) inches and i can just clear speed bumps. The car looks dropped but not over done theres about the width of my middle finger for the wheel gap.
Old Feb 22, 2003
JRS1civic's Avatar
JRS1civic is an unknown quantity at this point
try to avoid them as much as possible. if you can just angle and go through them sideways. my car is lowered about 2 inches, maybe even lower and i jsut angle.
Old Feb 22, 2003
M1kEzPr1NcEzZ
Guest
Posts: n/a
uh you wanna lower your car but don't wanna go sideways or slower? i suggest bigger tires in the front lol esp if you have a kit
Old Feb 22, 2003
amhtown01's Avatar
i dont kno why ppl swerve on speed bumps for...if u go slow enough the car wont bounce and hit the bottom. Either way the speed bump is gonna go through the bottom of ur car. so i think swerving is useless on speed bumps but a must on drive ways IMO
Old Feb 22, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
Quote
[hr]Originally posted by: amhtown01
i dont kno why ppl swerve on speed bumps for...if u go slow enough the car wont bounce and hit the bottom. Either way the speed bump is gonna go through the bottom of ur car. so i think swerving is useless on speed bumps but a must on drive ways IMO[hr]
if you go at an angle, the tire will hit the bump before the whole bumper is over it. this will lift the car before the bumper scrapes. i have a 2" drop and full xenon kit and i can get over almost every speed bump i encounter by going at an angle. but if i were to go straight i'd screw it all up.
makes $2500 for bags look like a good deal huh.
Old Feb 22, 2003
duyaknow's Avatar
duyaknow is an unknown quantity at this point
I run 205/45 tires, and have never scraped over a speedbump. I have it barely tucked in the back, but 1/2 a finger in front. I think 45 ratio tires will be your best bet for not scraping. Note that I said I never scrape over speed bumps, and that's just going straight trough them at slow speeds, and I don't really have to go that slow. I can go through them fast as my stock set up because I guess the B&G setup is a plus in that area. But I do scrap going up driveways and those incline. I really only scrape my exahaust because it hangs low. It's the cannister style (a big one).
Old Feb 22, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
Look at my ride, no link yet... I got 17's with an octane everything , but blitz off a 6th gen civic and gc coilovers with right about a 2 inch drop, i am near 2 inches off the ground. Most speed bumps, even those big long ones in the residential areas I can just go slow over.... with the residential ones i can go like 20 over them , barely angle if at all and not hit, my springs have settled well.... On the one in this **** hole apt complex I djust go slow over em... most of the yellow or white apt. complex type one , just go slow, no real need to angle.. try just going slow over em, if you scrap, oh well, try angling the next time.... If there is anything I've learn from having been rearend twice and scraping the front running from a raid, , and a hit and run to the drivers side... it wont be show all the time, and scraps on the bottom ( where noone checks anyway) dont matter that much... if you scrape, just try a lil slower, and a dif angle....
* you wont always have a clear shot, there may be parked cars, cars of a 2-way street, and so on, just be as carefull as you can until you get comfortable... I know EXACTLY when im going to scrap or bump and where, whenever I go over ANYTHING, it just takes some experience....
but try slow, try angle, try some things you might be afraid of trying ( maybe, depends on how paraniod you are, took me months to try random **** just to test my skills).
And, qiuck tip: always beware of places unknown, and of those dreaded double-angle inclines, god damn I can't tell you how annoying those are...
Any q's or c's, let me know....
Old Feb 22, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
H&R Sports + Mangaflow Catback=Scrape once in awhile
Go at an angle, but sometimes you just can't help it
Old Feb 22, 2003
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
CGodwin3103: "i can go like 20 over them "
you are gonna end up with struts through your hood
Old Feb 22, 2003
Vesper's Avatar
Vesper is an unknown quantity at this point
i really cant belive there is a topic about this. [IMG]i/expressions/face-icon-small-puke.gif[/IMG] it really does make me sick.
Old Feb 22, 2003
Kimo's Avatar
Kimo is an unknown quantity at this point
I've got neuspeede sport that's a bit still high but just to make sure i always take large bumps, humps with an angle.. we call it 'siete' here in the philippines - theres your hump _ (horizontal) take on an angle and you do a number 7 (your cars diagonal) siete - seven [IMG]i/expressions/face-icon-small-smile.gif[/IMG] .. if u really wanna be sure, go very very slow [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 24, 2003
TOOLOWCIVIC's Avatar
I used to scrape whenever my car wasnt dropped. Now that is dropped I dont scrape at all but Im careful though. There are a lot of messed up streets in Houston and my 19s make it worse so Im very careful.
Old Feb 24, 2003
Briareos's Avatar
Briareos is an unknown quantity at this point
This is why I refuse to drop my civic... Isn't your car supposed to be easy to drive? My old civic was dropped 2", and I trashed 2 body kits within a year or so, and I was an extremely careful driver. I think a drop only belongs on a show car... otherwise, you're just shooting yourself in the foot.
Old Feb 24, 2003
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Quote
[hr]Originally posted by: Briareos
This is why I refuse to drop my civic... Isn't your car supposed to be easy to drive? My old civic was dropped 2", and I trashed 2 body kits within a year or so, and I was an extremely careful driver. I think a drop only belongs on a show car... otherwise, you're just shooting yourself in the foot.[hr]
i think slamming the car to the ground would be for show... but having a little drop would improve the handling...
Old Feb 24, 2003
VNlilMAN's Avatar
The Standard One
dude, you guys make it sound like dropping the cars a big deal.. i dropped my car 1.75" and i ride it almost the same as when my car was stock. and of course when you lower the car you should take speedbumps at an angle, if you dont want to, dont lower it! only time when your going to have a real tough time clearing speedbumps is when your car is dropped 3" and you have a kit. most of us only lower the car 1.75" tho.
but ya it really isnt a big deal, just lower it and driving a lil more carefully will be worth it
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
