JET Performance ECU where can i upgrade my?!?!
blingbling member
does any one know where can i progam my ecu chip?!?! i got a a 2k1lxcoupe.....and will my speed governor be removed if i program my ECU?!?!?![IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Hail to the king baby
Chespest place to get the JET ECU upgrade is through JC Whiney online. It will run you $229.00
You get it custom programmed to your mods and you fill out on the sheet
that you would like the speed govenor removed and your RPM's raised 1K.
You will now be able to cross the finish line at around 88mph in 3rd gear.
Also, if you plan on getting N2O this is not a good upgrade since the upgrade will advance your ignition timing to by 5 degrees .
Good luck.
Good luck.
JetsterDajet
Aug 16, 2015 01:56 PM
