Original transmission but motor swapped. Will this cause problems?
Old Feb 7, 2003
boxcarpunk's Avatar
boxcarpunk is an unknown quantity at this point
I know this is not about the 7th gen. civic, but I wasn't getting any feedback in the previous gen civic section. Besides, this should pertain to any year. I just purchased a '96 Civic with what I'm told is a '95 EX engine. The transmission is from the '96 HX. The car has the strangest gear ratio I have ever seen where 3rd goes to 80 mph and THEN hits V-tec. The car does not accelerate very quickly and I am just curious as to if it could be caused by the transmission being for a different engine? If so, would getting the correct transmission for the motor correct this? Any help on this would be appreciated. Thank you.
Old Feb 7, 2003
MaxPSiLX's Avatar
MaxPSiLX is an unknown quantity at this point
The gearing in the HX tranny is more for fuel efficiency than the EX, so most likely it's your problem. Although both motors have Vtec, they also have different gearing for different needs....just find an EX tranny and you should be fine.
Old Feb 9, 2003
boxcarpunk's Avatar
That's what I was thinking, but it was just a thought and I wanted to run it by some other people before possibly replacing the transmission. Thanks!
Old Feb 9, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Also check out Club SI, they can help you better there.
Supramk3
May 11, 2015 07:55 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
mievil
Apr 28, 2015 11:02 PM
bsmiley
Apr 27, 2015 01:27 PM
Rinzlor
Apr 24, 2015 10:33 AM
