where is the water pump?
Old Feb 3, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
im looking for an engine diagram or if someone can tell me where the water pump is on our cars! PLEASE HELP!
Old Feb 3, 2003
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Water pump location:
Standing in front of car. Look at the valve cover. To the left of the valve cover where the big rubber hoses connect to from the radiator.
Best I can do without being there to show you.
Old Feb 3, 2003
BIGLIMPDOG's Avatar
are you talking about where the upper and lower radiator hoses go to with the theremostat right? if so that is what i thought but someone was telling me it was with the timing belt under the cover?! THANX
Old Feb 3, 2003
Barney's Avatar
Timing belt location:
Standing in front of the car. Look at the valve cover and the black plastic cover on the right is the cover for the timing belt. What I told you and what you thought were correct about the water pump.
Later, Phil
Old Feb 3, 2003
DathAnEteRnaLbBLuE's Avatar
DathAnEteRnaLbBLuE is an unknown quantity at this point
Hey barney, I was reading this thread and saw a link in your post of deepvision.net who do you roll with?
Dathan
Old Feb 4, 2003
slikor's Avatar
slikor is an unknown quantity at this point
Quote
[hr]Originally posted by: Barney
Best I can do without being there to show you.[hr]
That is not actually the location of the water pump, that is only where the return line for the radiator (and some other coolant lines) and the thermostat are located. The water pump is on the right side at the very back of the engine, where the belt is that goes to the alternator, power steering pump, etc. Here is a diagram (it is for an 01 EX, but would be essentially the same for lower models just without the EGR valve [#1]):
(#3 is the water pump)
Old Feb 4, 2003
Barney's Avatar
You are correct. The water pump itself is located there. What I mentioned was the thermostat. My fault.
Old Feb 4, 2003
BIGLIMPDOG's Avatar
where do i get one of those diagrams? And i guess the next question is should i try to do this myself or...
i need to take it and have done huh?
Old Feb 5, 2003
slikor's Avatar
I get all those diagrams I post from Majestic Honda Online, and they sell Honda OEM parts (which are listed in diagrams like the one above) for very low prices.
What is it you are planning to do...upgrade the water pump or something?
Old Feb 5, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
does the timing belt turn the water pump on these cars?
civic98?
Aug 13, 2015 01:32 AM
USCGBM
Aug 12, 2015 04:22 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
mrwhos
Aug 11, 2015 02:03 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
