URGENT HELP!!
Old Jan 22, 2003
Zigen1's Avatar
Zigen1 is an unknown quantity at this point
URGENT HELP!!
Im in a dilemna here, after cleaning the throttle body and everything was put back in place, the car's rpm became unstable oftentimes dropping to 0 rpm. Rpm would deliberately drop to 0 rpm when braking from neutral... this would happen more during mornings when engine is still cold. I was having this problem for 2 weeks now. I dont know what to look at, the tps, the throttle body itself, the ecu, electricals or the engine itself. I would appreciate ur inputs, thanx guys[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 22, 2003
flotsamm's Avatar
Assuming you have no air leaks(like from a bad gasket), perhaps check the TPS first. Could be IAC also. The ECU and electricals should be fine for the most part unless you frayed a wire or damaged them. If it throwing codes at you, perhaps take to the dealer(or other places that might have a scanner) and have it scanned. From there you can decide if its something you can fix or not..
Old Jan 22, 2003
TwilightX's Avatar
TwilightX is an unknown quantity at this point
You reset your ecu? Leave your battery disconnected for 10 minutes and then let her run till the car warms up...that might help as well...
Give a PM to Grey, he just got through issues when he touched his throttle body (:rolleyes[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
JUNITO
Jul 9, 2015 08:36 PM
PierrePierre
Jun 17, 2015 06:22 PM
kulcivic
Dec 23, 2007 09:20 PM
iahk_ueih
Nov 7, 2006 04:13 PM
mkingk2
Jan 25, 2005 06:08 PM
