B20 VTEC Hatchback
Old Jan 18, 2003
Toretto's Avatar
Toretto is an unknown quantity at this point
B20 VTEC Hatchback
bout to cop my 96 hatch and drop the B20 in it,
im bout to rip my brothers 1990 prelude si B20 out,
and drop the Type-R head on it.
make it my team track car.
Old Jan 18, 2003
dragoon's Avatar
1990 motor in a 1996 car? i would advise you find a newer block to drop in your hatch.
Old Jan 19, 2003
Toretto's Avatar
well i could just get a CRV block but its right there,
and im going to get it fully re-built from top to bottom.
i just want to get the block done then i can do everything else.
Old Jan 20, 2003
03_silver_ex's Avatar
03_silver_ex is an unknown quantity at this point
b20, different, its nice to see somebody doing a hatch and not a b16 or b18 for once.
Old Jan 21, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
the B20 in the 2.0 Si lude and the B20 in the CRV are way different. To make a good swap you would need the B20 block from a CRV rather then the engine you are thinking of using.
Old Jan 21, 2003
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
hondaguru is right. wiring in that engine would be a head and a half. you would be goin from OBDII to OBD0 or PRE-OBD, which would make things difficult, not to mention youre better off finding a new B20, considering it would perform MUCH better and has a lot less mileage/wear...
Old Jan 22, 2003
Toretto's Avatar
ya, i was lookin at this one on ebay, heres the link.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2400805161&category=33 615
Old Jan 22, 2003
Toretto's Avatar
see if this werks
b20 with vtec head
Old Jan 22, 2003
HondaGuru's Avatar
Description: "I want it to say B20 on the block to scare people." Regular CRV blocks crack running higher than 12.6:1 or so compression. Sleeve it, them make it 13:1 and get the most HP possible on the street! This block features the following details:
Iron Sleeves for total strength and durability
IB Spec Wiseco Pistons, JE pistons, or Arias Pistons. You choose!
Eagle Rods or Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
Compressions come in 9:1, 9.4:1, 10.5:1, 11.8:1, 12:1, 12.5:1. 12.8:1, 13:1
Price: $3650 Shipped.
http://www.importbuilders.com/block.html
Old Jan 23, 2003
Toretto's Avatar
well its a B20z which is better for running all motor right?
to raise compression couldnt you get a thinner head gasket?
just like if you want to lower your compression, just double up
or get a thicker head gasket.
Old Jan 23, 2003
HondaGuru's Avatar
CRV B20 for ANY application.
Old Jan 24, 2003
Toretto's Avatar
gotcha well im going to start piecing it 2gether to make a beast.
Domest killa.
Old Feb 21, 2003
Hondasport2k3's Avatar
i gOt da MaJik stiK
Hondasport2k3 is an unknown quantity at this point
Guru, how do you do the little signature dude taht holds the sign and tells me my IP, Windows OS, and stuff?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 23, 2003
HondaGuru's Avatar
Quote
[hr]Originally posted by: Hondasport2k3
Guru, how do you do the little signature dude taht holds the sign and tells me my IP, Windows OS, and stuff?[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
http://www.7thgencivic.com/forum/mes...threadid=78255
jammer48
Oct 4, 2018 10:04 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
Bonobo
Oct 2, 2015 06:58 PM
Islesfan
Sep 29, 2015 03:42 AM
Hatchness
Sep 14, 2015 09:02 AM
