headlight keeps burnin out
Old Jan 14, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
my drivers side haedlight keeps burnin out, i have had to replace it 3 times in the last 4 weeks. i have installed nothin new, and have nothinn runnin off of any lighting wires. anyone have an idea what could be causing this, its pissin me off and the guy who keeps replacin my bulbs.
Old Jan 14, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: profurious
my drivers side haedlight keeps burnin out, i have had to replace it 3 times in the last 4 weeks. i have installed nothin new, and have nothinn runnin off of any lighting wires. anyone have an idea what could be causing this, its pissin me off and the guy who keeps replacin my bulbs.[hr]
1. The light bulbs you are using have too much wattage (stock is 55/60w...you should stay close to this)
2. The light bulbs just plain suck (cheap brand)
3. He touched it with his fingers (oil kills the bulb)
4. Your wiring harness can't handle your bulb
Answer is simple....
1. Buy PIAA or MTEC bulbs
2. Clean the glass with windex and tissue before putting it on
3. Enjoy...
edit: You can find MTEC bulbs on ebay starting $3... they are as good as PIAA's
Old Jan 14, 2003
profurious's Avatar
I Am The Chosen One
1. lights are exact same wattage
2. they're sylvania silverstars, so they're not cheap
3. i installed them so there's no oil cause i wear latex gloves when doin any work to my car
4. the wiring harnes had no problem for the first 5 months, and now its all of the sudden
their has gotta be somtin else, i wish i new.
Old Jan 14, 2003
FALKEN's Avatar
Civicforums Junkie
Go back to stock for awhile and see what happens over time...
Old Jan 14, 2003
666's Avatar
666
666 is an unknown quantity at this point
I have found no matter what brand aftermarket bulb it is they always seem to burn out.
Old Jan 14, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
Quote
[hr]Originally posted by: 666
I have found no matter what brand aftermarket bulb it is they always seem to burn out.[hr]
yet another "i told you so" from me to you.
Old Jan 14, 2003
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
Latex burns too, even a few molecules, just be careful and dont touch the glass, even with gloves on, if that doesnt work, check the wiring.
Old Jan 14, 2003
HondaGuru's Avatar
just curious, are you TOUCHING the bulbs before you put them in?
Old Jan 15, 2003
murd0c's Avatar
murd0c is an unknown quantity at this point
I've had my PIAAs in for 1yr have had no prob best you can get but do cost a couple bucks
Old Jan 15, 2003
Toretto's Avatar
Toretto is an unknown quantity at this point
mine be burnin out to i have 90-100watt arctic white headlights but
i just return them to my boy that owns a performance shop and he gives me a new pair all tyme
Old Jan 17, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
i think ur problem is that theres oil on the bulb. when u change bulbs always wipe the buld with rubbing alcohol NOT WINDEX windex contains ammonia and other stuff that leaves residue on the bulb. rubbing alcohol leaves no residue and works perfectly everytime. also be sure not to scratch the glass on the bulb. hope this works
Old Sep 23, 2004
Black2k1's Avatar
Black2k1 is an unknown quantity at this point
i had silvania silverstar and i have a problem wiith passenger beam the DRL light come on but not at the same force compared a the driver side and the low or high beam not come on the fuse burn and if i replace the fuse im opening the light and oppssss the fuse burn right now
driver side no problemo what the f**k?
Old Sep 23, 2004
shmik1's Avatar
I had some APC superwhites, yea big mistake, burned out in 6 months, now I have silverstars, no probs yet I switched em when 1 APC burned out about hmmm? 2-3months ago. I had silverstars in my old car and had 1 burn out, just replaced the one and it was fine, but I didnt have the car for over a year after I put the new one in, so who knows maybe my silverstars will eventually die too.
Old Sep 23, 2004
Do you guys know there is a recall on some cars with faulty headlight wiring? Go have it checked.
Old Sep 23, 2004
civic4dizoor's Avatar
civic4dizoor is on a distinguished road
rfljnsgfkl'nal rvf,esg;emgndgfklnvfdlgnfdl;'g
Old Sep 23, 2004
Black2k1's Avatar
but the problem seem in the wiring or relay the bulbs was good and the new bulbs buying today is good
Old Sep 23, 2004
thetzer's Avatar
thetzer is an unknown quantity at this point
Um...this thread is over a year old.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
