Sticky tape underneath pinstrips&badge?
Old Jan 10, 2003
macadeezy's Avatar
macadeezy is an unknown quantity at this point
I just traded my civic EX in for a 2002 Si yesterday, and today I removed the ugly pinstrips and the civic badge on the back, and I forgot what I used to remove the left over tape underneath. What's the best stuff to use without destroying the clearcoat or paint? Thanks
Old Jan 10, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
WD-40 should do it
Old Jan 10, 2003
nme3's Avatar
JDM wannabe
goo gone works good to.
Old Jan 10, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
just spray on a lil goo gone n wax the spot.
Old Jan 11, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
tar remover or gew gone works great
Old Jan 11, 2003
e30iS's Avatar
e30iS is an unknown quantity at this point
like everyone else said...goo gone works. Make sure the car is clean before you start using it. Take off the badge, spray the stuff, let it sit, start buffing. Then go over with some wax.
And don't use wd-40 on your paint...
Old Jan 11, 2003
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Exactly!
I would shy away from using WD-40 on your paint..that's kinda extreme..but just make sure whatever you do, you do two things...
1) clean that spot first to remove any dirt so you dont push it into the clear..
2) wax the spot after your done[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jan 11, 2003
neoretromax's Avatar
neoretromax is an unknown quantity at this point
goo gone.
thread should have been posted in detailing forum.
Old Jan 11, 2003
bbguy5's Avatar
bbguy5 is an unknown quantity at this point
if u got a dremel tool they make a bit for it...that's how i debadged mine and got the glue off
chris
Old Jan 12, 2003
clownprince's Avatar
Ricerus Maximus
Acrysol is what I used, took the glue right off. Just be sure to wax afterwards.
SammySC
121
Apr 7, 2017 07:43 PM
Skunkone
Sep 24, 2015 04:38 PM
TheRiddicles
Sep 21, 2015 03:43 PM
MichaelLW
Sep 14, 2015 07:15 AM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
