homemade turbo w/MSD ignition questions???
back in october I finished designing/building/installing my own cobbled together turbo setup for my 98 ex 2-door from an eclipse turbo, a saab intercooler, some eBay sourced parts (like the manifold), and a bunch of home depot tubing and knuckle blood
The car really runs good from what I can tell and all but it has been running a little too lean for my sake....(runs at the very left of the "stoich" on my autometer pro-comp ultralite air/fuel gauge when under a full load...pedal to the floor...and I don't like this....
I got an aftermarket fuel pressure gauge and I just now got the rest of my msd ignition stuff from summit racing (bought a used sci unit and blaster ss coil from eBay the other week)...needless to say I think I've got enough coil wires to make an extra plug wire set haha [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
here's my questions:
1. I've heard and believe the rumors that there really isn't too much of a difference in spark plugs but I was going to go with bosch platinums anyway since I'm changing the whole ignition and the car's got 80k on it as is...what should I set the gap on the plugs at with the MSD ignition?? do parts stores sell the "colder" wires and if so what should I ask for??
2. anybody on here got an idea of a good place to mount the MSD unit and the blaster SS coil?? I hacked up my CP cold-air intake so that I at least had the bling bling inside the engine bay still and that way it looked a little more like stock too...as I also kept my heat shield from my original manifold and welded a stud to the turbo housing (I lightly tacked it) so I could try to "hide' the turbo too
3. how the hell do I tune this fuel pressure regulator?? It didn't come with instructions...though it's got a gauge on it (a cheap *** looking one...stupid budget and eBay...)
any ideas/suggestions would be greatly appreciated?? also what should I look for as in performance wise and will this help my leaning out problem before I melt a piston or something??
-stackz
-stackz
1- There is a difference on spark plugs. But not a huge one. Just get a quality plug, make sure it's gapped correctly (most important part) and you'll be fine. You don't need "colder" wires, only colder plugs, usually 2 degrees colder. Any AutoZone or O'Reilly's will be able to point you in the right direction.
2- Anywhere you can find it... I've seem people mount them just above the transmission using a custom metal bracket, or on the firewall toward the passenger side. Just wherever you like and can get it secured.
3- No idea, post a pic and brand name of the FPR and I'll try to help.
And before you worry about leaning out too much, go to a dyno and use their wideband o2 sniffer, Autometer gauges use the stock o2 sensor and are not very accurate, only useful for a rough guess. After you get this all installed, if you go to a local performance shop with a dyno, they'll give you a couple of pulls and tune the ignition and FPR for you, and you'll be good to go.
what would be a good starting point for the gap for the plugs??
are bosch platinums good??
how much does a dyno run cost roughly hehe??
thanks for the quick help...
-stackz
-stackz
I'm using .30" on my 01 Civic, it does vary from car to car though... AutoZone or O'Reilly's should be able to tell you. Otherwise do a search in Honda-Tech.com's Forced Induction forum for plug gap, you'll find what you need.
Bosch Platinums and Denso Iridiums are pretty much the same, and Bosch costs a lot less. Just have to gap them, as the Denso's come pre-gapped.
Dyno runs vary a lot from shop to shop, but expect to spend around $100 for them to make 3-4 runs with the wideband o2 sniffer and tune your ignition and fuel.
Civic65
Jul 19, 2015 10:13 AM
NoobyKid
Jul 13, 2015 07:53 AM
