ECU for Turbocharging... (Grey?)
Old Jan 5, 2003
JohnyBlaze's Avatar
JohnyBlaze is an unknown quantity at this point
If I go with a standalone ECU like Haltech E6K, I'll have to remove my check engine light, and I'll lose the immobilizer security functionality won't I?
I'm also thinking about having Hondata flash the stock ECU with new base maps (accounting for larger fuel pump and injectors) -- this way I get to keep all of the stock ECU functionality and let the stock ECU control everything, even under boost. Would this work? Can the stock MAP sensor handle up to 8-10psi of boost?
For the custom turbo setups that already exist, how is ignition timing retarded? I know that eveyone is using additional injectors with a microfueler controller for additional fuel under boost, but what are people doing about ignition timing under boost?
I'm hoping to do a turbo setup using a mitsu 16G and larger fuel injectors (and pump) and have the ECU control everything -- extra fuel and retarded ignition under boost. What do you think of that design?
--J.
Old Jan 5, 2003
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Quote
[hr]If I go with a standalone ECU like Haltech E6K, I'll have to remove my check engine light, and I'll lose the immobilizer security functionality won't I?[hr]
Correct.
Quote
[hr]I'm also thinking about having Hondata flash the stock ECU with new base maps (accounting for larger fuel pump and injectors) -- this way I get to keep all of the stock ECU functionality and let the stock ECU control everything, even under boost. Would this work? Can the stock MAP sensor handle up to 8-10psi of boost?[hr]
Dunno about the stock map sensor, but Hondata cannot modify our ECU's yet, they are still in development and have not released anything for our cars. To reflash for new injectors, the car must be dyno tuned, and the chips modified in the ECU to accept a reflash.
Quote
[hr]For the custom turbo setups that already exist, how is ignition timing retarded? I know that eveyone is using additional injectors with a microfueler controller for additional fuel under boost, but what are people doing about ignition timing under boost?[hr]
Absolutely nothing, mine runs just fine on stock ignition timing and 8psi.
Quote
[hr]I'm hoping to do a turbo setup using a mitsu 16G and larger fuel injectors (and pump) and have the ECU control everything -- extra fuel and retarded ignition under boost. What do you think of that design?[hr]
Sounds good, as soon as you find an ECU that you can use... AEM is promising an application with basemaps within 6 months, and Hondata said within a year, I talked to them 4 days ago.
Old Jan 5, 2003
JohnyBlaze's Avatar
Even when AEM comes out with an EMS for our application, won't we still lose the immobilizer functionality?
Can the Haltech be wired to keep the check engine light at least?
Old Jan 6, 2003
First to spool
Not sure about the immobilizer on the AEM... some cars lost it, some not. Most have lost it though.
The Haltech has basic on board diagnostics, and could be used with the check engine light, but not as extensively, very few things would trip it unlike with the stock ecu.
Old Jan 6, 2003
JohnyBlaze's Avatar
Okay... so my shop talked to Hondata and heard the same thing: nothing for our cars yet.
Since I don't want to lose my immobilizer, I guess I'll do what other people are doing.
So I'll go with 2 extra injectors, a larger pump, Missing Link Valve, and I'm also going to go with the GReddy e-Manage system to control the extra injectors and retard ignition under boost.
Is this a sound design?
--J.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
dhuff
Sep 28, 2015 08:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
260000milesgoal
Sep 25, 2015 07:41 PM
