02 Parking light wire....
Old Dec 29, 2002
Manofsteel's Avatar
Manofsteel is an unknown quantity at this point
According to D I Y, the parking light wire is red/yellow... I found the wire, and yes, it gets 12V when I turn on parking lights. However, is there a wire from the main steering column harness that has it? The red/yellow is not a part of it.
Old Dec 30, 2002
Cokafka's Avatar
Cokafka is an unknown quantity at this point
The parking light wire is the blue wire on the switch (on the steering column) it is a negative system. The system is a negative system when you touch a ground to the blue wire the lights come on. If you have a positive output from an alarm (more than likely) you need a relay to reverse the polarity.
Old Dec 30, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: Manofsteel
According to D I Y, the parking light wire is red/yellow... I found the wire, and yes, it gets 12V when I turn on parking lights. However, is there a wire from the main steering column harness that has it? The red/yellow is not a part of it.[hr]
No. The wire you wanna be looking for the the red/black. See pic.
HTH
-Kre
Old Dec 30, 2002
Cokafka's Avatar
Is it different between models? I have a DX and I tapped into the blue wire on the column with a relay. If so mind my stupidy
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
GhettoCivic
Nov 12, 2001 03:15 PM
wawacito
Nov 5, 2001 03:32 PM
NukeSilo
Nov 4, 2001 09:37 PM
