Box recommendations for a 15" Eclipse Alum
Old Dec 26, 2002
2k2civic's Avatar
Anyone have any experience with these subs? I would like a box that will get loud but also have some kind of SQ. It will be powered by a DEI 1100D. Let me know what kind of box I should use for this sub. Thanks.
Old Dec 26, 2002
mohawkboom's Avatar
Oh I have tons experience with them...
they work optimally in 1.4 cu.ft for the DVC models, 1.55cu.ft for the SVC models...the DVC 4ohm versions don't play as low as the SVC's but have overall better SPL capability in the higher bass ranges.
If your gonna run a pair I'd suggest you put them in 1.6cubes each and stuff each one with a 2lbs of polyfill for the added low end response.
If you want to sacrfice your entire trunk the DVC alums actually work extremely well ported..in 2.2cubes each tuned to 33hz via 2 3" aerovent ports for each sub you'll have a very even frequency response in car and it will get really really loud [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 26, 2002
2k2civic's Avatar
I only plan on having one of those. Do you think you can help me build the box (I would need some kind of drawn diagram, this is my frist time building a ported box that didn't have slot type vents).
Old Dec 27, 2002
mohawkboom's Avatar
only 1 sub..the DEI only puts out 600Wrms into 1 of them...if you want to get a 4ohm mono amp I'll sell you my pretty much Brand new 15" Eclipse alum for $350 shipped in a 1.55cu.ft sealed box..
sccarally
Texas
Aug 21, 2015 10:09 PM
h4ldol
19
Jul 28, 2015 01:01 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
