AEM Short Ram installation...
Old Dec 25, 2002
BaNgCiViC2k1's Avatar
BaNgCiViC2k1 is an unknown quantity at this point
ok i got my aem shortram intake for my 2k1 ex 2dr..
First thing it says is to remove battery cables from fuse box aright so it has a head for a screwdriver, take out the screwdriver... **** is so tight it starts stripping, i let my friend give it a try and no luck getting it off...
then i try to remove a bolt from the stock intake manifold, very tight could not loosen it at all. Im thinking maybe i need diff tools or something becuase no madder how hard i try nothing wants to loosen just strips from all the pressure.
any ideas [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 25, 2002
CarbonFly's Avatar
Yea, those screws are kinda tight. I would just take off the negative battery cable. It's not really that big of a deal, just a safety measure. Make sure that you have good quality tools like craftsman or something.
Old Dec 25, 2002
CapYoda's Avatar
Escaped Convict
u should be able to take out the bolt for the negative battery via a socket wrench...
what kind of wrench are you using? is it long enough so you can have more torque applied to it? better tools will help. I can take the stock intake assembly out in 5-10 minutes.
on another note, AEM wants u to take out the negative so u can reset the ECU. its not really a safety issue.
Old Dec 25, 2002
rijowysock's Avatar
ThE FaMiLy SeDaN
hey capyoda i ordered my AEMSRIand it should be i next week can you give me a basical outline of what i need to do. i know here is instuctions ETC. but from your point of view where youve done it bfoe you know all the short cuts or unneccesary steps.
riley
rijowysock@aol.com
AIM: rijowysock
p.s. i have a 2001 lx sedan
Old Dec 25, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
dont use the philips screw driver. all you need is the 8MM for the airbox lid and 10MM for the airbox assembly.
Old Dec 26, 2002
8mm and 10 mm wrench, will that take the bolts and stuff out
Old Dec 26, 2002
cvc2k2's Avatar
didnt i say that?
Old Dec 26, 2002
okay thanks just making sure im gonna go out and give it a try tommoro[IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 26, 2002
CapYoda's Avatar
Escaped Convict
Quote
[hr]Originally posted by: rijowysock
riley
rijowysock@aol.com
AIM: rijowysock
p.s. i have a 2001 lx sedan[hr]
like everyone said, 8mm and 10mm socket wrench... thats all u really need.. a flathead screwdriver will help too.
once u take out everything its pretty straight foward.. check out the DIY section for the CAI DIY if u need help on taking out the stock airbox... there's really no short cut, just take out all the bolts...
remember, just take out the stock airbox.. nothing else. dont need to worry about the transmission mount since you dont have a CAI.
Old Dec 27, 2002
ok i got the 8 mm and the 10 mm and wrench at pepboys and installed it today in the parking lot.. i went for a ride and at like 6000 rpm its mad loud, so everything seems to be working fine, thx
Crazygrlinak
Oct 8, 2015 05:06 PM
Le Ormz
Sep 30, 2015 09:24 AM
Cam Diaz
Sep 29, 2015 07:17 PM
Hutch1051
Sep 29, 2015 09:20 AM
