I hope someone can help me with this question?
Old Dec 21, 2002
Rollin0n18s
Guest
Posts: n/a
I was wondering what the amp rating on a stock 2k1 civic alternator and what would be some of the benfits of upgrading the alternator to higher amp
Old Dec 21, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Answer to your first question would be in your owners manual, i know that doesnt help but i dont want to spit out a number if im not sure. (i want to say something like 120 - 140 amp though, rough estimate)
Second question would be that your battery stays fully charged during normal driving conditions, and you will not notice wuite as much of a power loss when using multiple high draw components (turning on headlights, rolling down windows and opening your sunroof while honking your horn and blasting your 600 watt stereo system all at the same time, oh yea, all while using your windshield wipers and defrosting your rear window)
Old Dec 22, 2002
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
- Not exactly sure here, but I think that upgrading to a high output alternator will take a way a little bit of horsepower (the opposite of an alternator pulley adding horses because the alternator isn't putting out as much power)
The only reason you would need to get a higher output alternator is if you are running a BIG sound system, or a lot of ICE.
Old Dec 22, 2002
Jalegr's Avatar
Jalegr is an unknown quantity at this point
Dead right GhettoCivic. You would also cut into your Miles Per Gallon with a high amp alt. I would run all the electic goodies with the stock alt and check that the battery will hold the volts that it does without all the goodies on before you go and change out the alt.
Food for thought.
Would the factory wire harness (and all the fusible links built into it) carry the power of a high output alt if you did go with one?
Old Dec 22, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
80 amp alternator stock, upgrading will not hurt your fuel or horsepower.
Old Dec 23, 2002
LudlamTheory's Avatar
i boogie for the raindrops
80 amp cold, 70 amp hot... hot rating is more realistic since your car will be running
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Causemo
Jul 4, 2015 07:11 AM
dosmastr
May 5, 2015 12:19 PM
