Intake Question?
Old Dec 16, 2002
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
Intake Question?
I already have my intake in for a while now. The question is I noticed other cars on this site, (by the way I have Injen CAI) have their hoses going over their upper pipe of the CAI, I tried putting the hoses over the pipe, but it felt tight and as if the hoses were to come off, so I put it under the pipe. Is it possible (because some of the hoses touch the pipe) that the heat from the intake pipe melt the hoses? and how did you people with Injen CAI's get the hose over the pipe. Did you just force it or what? Heres a pic of what I'm talking about. Thanks
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Oct12_10.JPG (34 Kb)
Old Dec 16, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
i cut mine shorter.... my hose has been cut..
Old Dec 16, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
I got AEM and it hooked up perfectly, but cut and lengthen as needed.
Old Dec 16, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
i placed all the hoses underneath the CAI except the 2 cables.. they go over the pipe
Old Dec 17, 2002
2k2civic's Avatar
Ummm, I would really rethink that move. That intake does get hot enough to melt those hoses and one of them is a fuel line, not sure about the other though. Just don't want you to burn through one of your fuel hoses...might cause a tiny problem.
Old Dec 17, 2002
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Quote
[hr]Originally posted by: 2k2civic
Ummm, I would really rethink that move. That intake does get hot enough to melt those hoses and one of them is a fuel line, not sure about the other though. Just don't want you to burn through one of your fuel hoses...might cause a tiny problem.[hr]
Actually this is completely false. I have the Injen CAI and it does not get hot enough to melt the lines. I have all the lines running under it. I have had it this way for about 6 months and no problems. Even in the middle of summer when it is the hottest. Just my 2 cents.
Old Dec 17, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Well, if your intake gets THAT hot.....you have more to worry about than a fuel line. Your intake piping shouldn't get any warmer than the temperature in the engine bay. So the fuel line is going to get that hot if it's hitting the pipe or not. I've had my lines run underneath my intake since I put it on (over a year) and no problems so far....
And just a little FYI....there is a throttle body heater that causes your throttle body to heat up (obviously) when your engine is running. If your intake pipe is pushed down all the way and is touching the throttle body......it's going to heat up a bit more due to the heat transfer. I backed mine off about a half inch and the intake pipe stays much cooler.......and doesn't sit high enough to hit the hood when I close it.
Old Dec 17, 2002
cvc2k2's Avatar
Is my CAI's lower arm installed incorrectly? My Injen RD CAI is bolted in the wheel well. How come AEMcivic is bolted on the engine? mine is installed very similar to JDMcivic.
Old Dec 18, 2002
AEMcivic's Avatar
I have a 5-speed EX, what do you have?
Old Dec 21, 2002
cvc2k2's Avatar
2002 Civic 5speed as well.... the CAI was not mounted onto the engine for my Injen RD. It was mounted onto a bolt inside the wheel well near the filter.
carid
Nov 7, 2015 01:46 AM
Farticle69
Aug 6, 2015 08:02 PM
spyder13
Jul 31, 2015 06:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
