rear upper strut install
Old Dec 16, 2002
ironcow's Avatar
ironcow is on a distinguished road
ok i have two of the four bolts off, i cant get the other two
they own me, the wrench i have i cant get enough tourque and i cant get my socket wrench to fit over the screws
any suggestions for removal
Old Dec 16, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
you need either a deep socket for your socket wrench, or use a breaker bar on the wrench you have to give you the extra leverage to pop it off.
Old Dec 16, 2002
ironcow's Avatar
where can i get a deep socket or a breaker bar?
Old Dec 16, 2002
civicvtec1ps's Avatar
Search and Learn
Quote
[hr]Originally posted by: ironcow
where can i get a deep socket or a breaker bar?[hr]
sears
Old Dec 16, 2002
2k1sscivic's Avatar
2k1sscivic is an unknown quantity at this point
Any auto parts store; Pepboys, autozone, kragen, sears
Deep socket works best IMO
Old Dec 16, 2002
ironcow's Avatar
i hope i dont strip the bolt, that would suck *****
Old Dec 16, 2002
KeNsHiN's Avatar
LEVA
Quote
i hope i dont strip the bolt, that would suck *****[hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] i know the feeling [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] just make sure you get the perfect size becasue trying to get off a striped is a bitch!
Old Dec 16, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
14MM.. deep socket..
you will need to modify the bracket for your driver side rear upper strut bar.
Old Dec 16, 2002
xblkcivicx's Avatar
you can use anything that will fit over your wrench for a breaker bar...(ie. a pipe) just put it over the wrench and it makes it an extension, giving you more leverage. You wont strip the bolt if you use a 14mm socket/wrench...should fit perfectly.
Good luck.
FYI: i had to dremel out some of the metal to get mine to sit flat...Might want to check that before you install it.
Edit: I was talking about the metal on the floor of the trunk.
Old Dec 17, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
i used half drive craftsman whenI took mine off I dont knwo if I would recomend using a breaker bar. If there that tight which they should not be (35 ft lbs. is spec) than a breaker bar would be bad because you might just twist the bolt right off the strut that would be worse than rounding the nut out be carefrul you a GM's heat valve penetrate that is some incredible stuff when it comes to breaking bolts loose
bryden13
May 18, 2015 12:22 PM
Thees1
Apr 14, 2015 08:23 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
