Adjusting TYC headlights? HELP!!!
Old Dec 13, 2002
blackbullet's Avatar
The Legend
I did a search and really found nothing. I know there are two screws that are behind the low beam, but how do I adjust the low beam? The left beam is too high, and I need to lower it a little. Would I have to "unscrew" both screws a little? Or do I only "unscrew" one of them? Do I tighten them? Which way lowers the beam and which way makes it higher? Any help would be appreciated. Thanks.
Old Dec 13, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Can someone help??
I need to know this too
Old Dec 14, 2002
Macko's Avatar
Macko is an unknown quantity at this point
my left beam is a little high too...
Old Dec 14, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
the screw on the bottom (hardest to reach) is to adjusts the low beam up and down. the one on the top adjusts the beam left-right. as for direction, i don't remember but there should be a diagram on the headlight that shows clockwise or counter-clockwise. if your not sure, just play around with it and look how the beam is moving on a wall or your garage door as you are turning.
Old Dec 14, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
There are screws? My right (passenger) side hi-beam lens is knocked back into the headlight casing, anyone ever have that? I'm probably going to end up having to dismantle the entire assembly and fix it, which sucks ..
But I say again, what screws ??
Old Dec 14, 2002
CarbonFly's Avatar
When I put my TYC's in, it took me 45 minutes adjusting the headlights before I got them how I wanted it.
What my friend and I found out was this.
1. one of the screws moves the light down and left
2. the other screw moves the light down and right.
So, you have to turn both screws to move it up, down, left, or right.
IT"S A PAIN IN MY A$$ ...........but my lights are perfect now.
Old Dec 14, 2002
misio4's Avatar
misio4 is an unknown quantity at this point
i had to take the bumper and the light out to adjust it
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
