Can't get strut tower bolts off to install front upper strut bar... WTF?
Old Dec 5, 2002
FurBall's Avatar
FurBall is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
WTF.... I bought a Ractive front upper strut bar, and now I can't get the 3 bolts off on the strut towers.... [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
WTF? This is like one of the easiest DIYs yet I can't do it.... I bought a cheap $10 rachet set, and when I applied all my weight into it (turning counter clockwise), the stupid thing about stripped the nut!!!
WTF.... How stiff are they supposed to be? I'd feel like an idiot if I had to pay money to get someone to help me install this..
Any suggestions? Someone suggested that I try WD40 on the bolts first.......
Old Dec 5, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
get yourself a good ratchet set (like craftsman) and get a long handle so you can get leverage... they shouldnt be that tight...
Old Dec 5, 2002
CarbonFly's Avatar
go to the store and get some ELBOW GREASE!!!
Old Dec 5, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
use your muscles, it will come off, just work on it.
INJEN
Old Dec 5, 2002
civicvtec1ps's Avatar
Search and Learn
yea its pretty hard to take those off. try to use WD-40 . worked out for me
Old Dec 5, 2002
KeNsHiN's Avatar
LEVA
damm dude i fu*ken hate bolts!!!!! i have this fear of striping them.....i know am weird
Old Dec 5, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
They're only on there with 33 ft-lbs. It shouldn't take all that much. (6" rachet handle, apply 66 lbs. if you're putting all your weight into it, you must be a real light weight.)
Are you using METRIC sockets? Cuz if youre using English, you probably have a socket that's too big and you're just ripping up the bolt.
Righty tighty, lefty loosey. Sounds like you've got that part down.
When it's on, torque it down to 33 ft-lbs (it's like 1/3-1/2 a turn past tight). Don't go too far, or you'll bust the threads up.
Old Dec 5, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
If you're smart, you'll be putting them on with a torque wrench. Use that same wrench to take them off.
Old Dec 5, 2002
Chris2k1civic's Avatar
Super Member
Chris2k1civic is an unknown quantity at this point
some one needs there oats today...
Old Dec 5, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
Quote
[hr]Originally posted by: Chris2k1civic
some one needs there oats today...[hr]
haha. maybe try pounding it with a hammer or something. just make sure it's a METRIC socket and you're turning it counter clockwise and you won't strip the nut
Old Dec 5, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Get a nice long pipe to fit over the handle of your socket wrench (or breaker bar). This will give you some extra leverage to loosen it (gently!).
....and DO NOT use a pipe/breaker bar to tighten the nuts back up.
Old Dec 5, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Jack the car up so the front wheels are JUST off the ground...this will relieve some pressure on the struts and make it easier to take off.
Old Dec 5, 2002
djmota's Avatar
.....Wheaties man Wheaties
Old Dec 5, 2002
OMega's Avatar
OMega is an unknown quantity at this point
Uh, far as I know you should only use a torque wrench to tighten not to losen. Something about screwing up the calibration.
I say you need to use the force or by liquid wrench. Using the force in is cheeper just rember to avoid the pull to the dark side(using standard tools).[IMG]i/expressions/laugh2.gif[/IMG]
Quote
[hr]Originally posted by: SMX
If you're smart, you'll be putting them on with a torque wrench. Use that same wrench to take them off.[hr]
Old Dec 5, 2002
certain torque wrenches can be used to loosen. the ratchet type generally can.
Old Dec 5, 2002
Grey's Avatar
DIY King
How long is the handle of that rachet? If it's like 4" long, then you might have a problem. Mine smallest one is 8" and I can take off those bolts without a problem. The car has like 16,000 miles and it's still not a problem to take them off. You're stripping the bolt? The socket you're using is probably not the right size. It's metric, so make sure it fits very snugly. There should be no movement with the socket on the nut. Well, okay... Maybe a tiny bit of movement.
Old Dec 6, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
hmm mine came off ok.... oh well.. just make sure they're torqued down when done[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Switch BL4D3
23
Apr 24, 2015 06:57 PM
GH04si
Apr 15, 2015 08:13 PM
jessepimpride
Nov 13, 2001 05:59 PM
PlatnumBomb
Bolt-on Engine Performance
Nov 9, 2001 01:11 PM
2Hondaz
Nov 8, 2001 11:00 AM
