Camber Kit Q
Camber Kit Q
Hi i recently bought a rear camber kit and going to purchase a front one soon from Greg. I was wonder if it's better to do it yourself and save some money or take it to a shop and do it. I know it is not that hard to install but i dunno about the degree's and etc. can someone tell me how that works if i do plan to install it myself with friends? thanks
there is not much to it if u r familiar with basic mechanical skill,make sure u have equal distance on both side of the turn knuckle b4 u install the part and the ABS sensor cable is not in the way, follow the instruction,good luck
It's easy to do. Just remember that on the rear, you have to loosen the bolt, NOT the nut. (The nut is permanantly attached to the hub carrier). I think I wasted 1/2 an hour trying to loosen that SOB up. [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
The Standard One
keep in mind the place you get it installed at isnt going to really adjust it for you. i'd say save the money and install it yourself but use that money you saved and get an alignment
Quote
[hr] It's easy to do. Just remember that on the rear, you have to loosen the bolt, NOT the nut. (The nut is permanantly attached to the hub carrier). I think I wasted 1/2 an hour trying to loosen that SOB up. [hr]
DIY King
Did you take a look at my DIY? DIY: SPC Rear Camber Kit Details
Quote
[hr]Originally posted by: VNlilMAN
keep in mind the place you get it installed at isnt going to really adjust it for you. i'd say save the money and install it yourself but use that money you saved and get an alignment[hr]
anybody out there know what the standard charge is for installing these camber kits. I'd like to do it myself but don't know if I have the tools. What kind of killing would I be in for if I had the shop install them for me?
The Standard One
i heard shops charge $100 which is ridiculous.. what tools do you really need.. jack stand and wrench, even if you dont have the tools, it wont be anywhere near $100 to buy them
Dave Brabant
20
Oct 6, 2015 12:44 AM
Hutch1051
Sep 29, 2015 09:20 AM
