Car Died
Old Nov 14, 2002
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
Car Died
I was leaving school today and I had been driving for maybe 5 minutes and I had to stop at a light to make my left and while I was sitting there it felt like my car stalled out. Well I have an auto so it wasnt like I slipped off the clutch, I look at my RPM's and sure nuff it was on 0. I was like f**k now what I tried to crank it back up but nothing. Of course by now Im pissed of its an 02 car almost brand new it should just be dying on me. Well I remembered back to this past weekend when I took my system and the wires out I had to undo a fuse to take I think it was the remote wire out(turns out its the ignition fuse) and I stuck it in wrong and the car wouldnt crank. So I took the plastic under the wheel off and reached under and found the fuses, when I would press in on the ignition fuse I could start the car but as soon as I let off of it the car would die again. I half *** it to the mall driving while hold in the fuse and trying to steer. I took the fuse out and it wasnt blown so I stuck it back in and it did the same thing. I called my sister at this point thinkin **** time to be towed. Pulled the fuse out one more time and jammed it back in and to my surprise it cranked up as normal but it idled a lil higher than normal, so my sis gets there and we head for my house well I stop at a light and I notice my RPM's still a lil higher than normal then it kinda just drops back down to where it normally sits. Am I in trouble, is it just a fuse or something major. Someone please help
Old Nov 14, 2002
flotsamm's Avatar
Not sure about the fuse block, maybe check the wires in the back. About it idling a little higher, this is common if the engine temp drops. It should however go back to normal idle speed after the engine is warm again.
Old Nov 18, 2002
myhonmyhonda's Avatar
myhonmyhonda is an unknown quantity at this point
I was leaving the highway into an exit ramp. As I was slowing down to about 30mph my car died on me. I had to crank it back up. I then stop the car and everything was ok. but the mystery was why did my car died on me?
Old Nov 18, 2002
flotsamm's Avatar
Maybe your part of the ignition TSB recall? Not sure.. but it sounds similiar to this..
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
