2002 center dash console panel removal
Old Nov 1, 2002
jaaaapp's Avatar
jaaaapp is an unknown quantity at this point
i want to paint the center dash panel and the two a/c outlets but i have no clue how to remove them. can someone help me?
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 1, 2002
civicvtec1ps's Avatar
Search and Learn
DIY
Old Nov 12, 2002
jaaaapp's Avatar
so i need to take out my center console in order to remove the center trim with a/cs and stuff rigft? what about the two A/C outlets? do i ply it out?
Old Nov 14, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
actually, you don't need to take the console out, that is an extra part. All you need to do to get to that bracket with the two screws that hold the cd player and all that good stuff in the dash is to take out the panel with the a/c plug right above the console. It is held in by clips. Work your way around the sides with a screw driver to dislocate the clips and should just come out. Hope this helps!
Old Dec 11, 2002
jaaaapp's Avatar
so sorry to reply late... but just wanted to reconfirm something before i actually do it..
if I understand correctly, do i just pull out those ***** for a/c controls, then use flat tip screw drivers to disconnect the clips? it'll be great if you can tell me how many clips there are and approximately where they're located. oh, and what about those a/c ducts? works the same way?
Old Dec 11, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
You could do it that way...but the best thing is to push up and out on the bracket that holds the CD player cluster in....you have to push hard, but to no avail, it will come out...if you try and pry the clips out along the actual trim piece itself you may run the risk of having the screwdriver slip and scratch...plus the harder you pry, the more it messes up the plastic..trust me, I have done this like a hundred times....
2Hottie
Old Dec 11, 2002
jaaaapp's Avatar
ok i'll do that! thanks. oh, is it better to get to those brakets by just plying the cig.plug console n locating the clips, or take out the center console(around the shifter) n remove piece by piece?
[IMG]i/expressions/beer_yum.gif[/IMG]
CarStuff
Dec 6, 2020 12:52 PM
IB Jose
Site News
Jun 2, 2015 12:58 PM
dariusld
May 29, 2015 12:44 PM
izdman
May 19, 2015 03:43 PM
NeoMagus
Nov 17, 2001 07:29 AM
