AEM/Injen CAI vs. K&N FIPK
Old Nov 1, 2002
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
I am about to purchase a K&N FIPK for my 02 LX 5-speed on a group buy. I was wonderin wut are the pros and cons of getting either intake. Which one is better?
(search didn't help)
Old Nov 1, 2002
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
personally i like the aem better...they make the only water by-pass and aem is the know intake system...in my opinion its the best on the market...but still intake are still just pipes with a filter on the end and the aem filter is made by k+n.....Come to think of it your good with which ever you choose...If you are going to do a cold air intake (the one that drops below the engine) make sure you get a water by-pass
Old Nov 1, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
Quote
[hr]Originally posted by: BlueBullet
personally i like the aem better...they make the only water by-pass and aem is the know intake system...in my opinion its the best on the market...but still intake are still just pipes with a filter on the end and the aem filter is made by k+n.....Come to think of it your good with which ever you choose...If you are going to do a cold air intake (the one that drops below the engine) make sure you get a water by-pass[hr]
just to make sure you learn a little before you make a retard comment about intakes
the k & n fipk is "cold air" it has a well designed heat shield. no model needs that bypass valve, cause its a waste of money unless you drive in lakes (the pressure in the intake tube has to change for it to work).
Old Nov 1, 2002
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
I thought that the FIPK was closer to a Short Ram than a CAI... Short rams don't need bypasses unless you literally decide to drive underwater. [IMG]i/expressions/laugh2.gif[/IMG] The gains between all the intakes are more or less the same. AEM claims to have the highest gains, but I dunno about that. The main difference between the AEM and INJEN CAIs are the locations. AEM is in one of the hotter parts under your hood. INJEN is behind the bumper, so it's cooler. However, it doesn't really matter that much which one you get. They all do the same thing and the gains are comparable.
Old Nov 1, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
I started off with the AEM intake and switched to the K&N FIPK. The K&N FIPK is a much better design . Less low end torque loss and not as loud and ricey sounding.
Old Nov 1, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
Base your decision on which sticker you'd rather have on your window...[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 1, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Quote
[hr]Originally posted by: SMX
Base your decision on which sticker you'd rather have on your window...[IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] I hope thats a joke
Old Nov 1, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Life is full of lemons.
I was in a rush and took my car to a quick lube. I had installed the K & N filter and told the dude twice to leave it alone, not to even open it.
Well, they did and I saw them playing around. Turns out they cross threaded the bolts holding the air box together. I almost did not even know but I was curious to see if they swiped my filter. I was pissed and went back and raised holy poop.
I got an estimate from Honda to replace the stock box and then took it back. With check in hand I pondered what to do. I said oh well and bought the FIPK. All I can say is what a difference!
Much more torque from 3000-6000 and it is much more fun to drive. It does get a bit noisey at 4000 and up, but it is still quiet if you are not on it hard.
Installation was a breeze. They used the stock mounting points, so there is no surprise and nothing to take apart on your transmission as in other units. The heat shield does keep a lot of heat away from the filter. I have an electronic thermometer on my Fluke and it keeps the temp almost 20 degrees different. Add to the quicker throttle response and the end to the lag from 2000 to 3000, and it is way worth it. Plus it looks much cleaner and will last the life of the car.
It is not flashy, it is all function, but it is pretty impressive looking at. You open the hood and notice this big air filter right away. Plus it looks as if Honda had put it there. I understand why the Honda dudes did what they did. They wanted a quiet car, but that box killed performance. I have not noticed any loss in torque or low end power, in fact the car does not bog as much and is much easier to drive.
I bought the K & N because I trust their stuff and have always used them. Plus they gave me a free recharge kit. If you are thinking about getting this unit, I say do it, and I don't say that lightly.
Peace.
Old Nov 1, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
i acutally have low end gain with the k&n fipk and even better high end gain!!
Old Nov 1, 2002
yes, do it, u'll find out its worth it[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 1, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
i cant really speak for the aem cai, but as for the fipk i have one and it is nice. evens out the power band a bit, almost no low end loss, and increased high end, is quiet until you hit about 4000 rpm then gets loud, and it looks good in engine bay, kinda like a stock performance intake or somethin. cant go wrong with k&n.
Old Nov 1, 2002
HomerSimpson's Avatar
Quote
Also remember that the sticker is at least 10% of total HP
Cam Diaz
Sep 29, 2015 07:17 PM
jordan1794
Jun 11, 2015 09:14 PM
Wild Cranker
May 19, 2015 06:10 PM
GabberHead
Jan 20, 2002 04:54 PM
