New suspenion set-up I may be getting...
Old Oct 24, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
I may be re-doing my whole suspenion in the next two months.
Currently all I have is Skunk2 Coil-overs which is a great drop, but way too noisy.
So I have started saving up and will be putting this in my car pretty soon. Also are there any other parts I should buy to have a COMPLETE suspension done?
Just as a side note, does anyone know if the RSX Mugen front strut bars(Or any other Mugen Suspension part) will work on our cars?
If anyone knows where I can get this stuff for cheaper please do tell.
Tein Flex Suspension - 1800
DC Sports Lower Tie Bar - 150
DC Sports Front Strut Bar - 180
Ingalls Front and Rear Camber Kit - 180
DC5R Rear Lower Sway Bar - 142
Tein EDFC - 400
Old Oct 24, 2002
VNlilMAN's Avatar
The Standard One
Tein EDFC - 400??
is that the electronic damper system thing?
man if your spending that much money on your suspension i would just bag it. but then i'm not much of a performance buff as i am a show person.
Old Oct 24, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
EDFC will not work on our cars, not room under hood. Any RSX strut bar should work, you just have to drill holes for it(two on each strut tower, 2-4 on the firewall and have to move the brake cylinder(i think). I want the mugen roll cage. That should fit, at least the front, and B pillar mounting areas. But who knows, got to do more research.
Old Oct 24, 2002
ASWZero's Avatar
You should get the SPC full camber kit which is about $300 and it includes the Front and rear camber kits and the aluminum rear lower arm. This lets you go extremely low with minimal camber in the rear. The lower arm brings the rear camber out half a degree(from -1.0 to -.5 degrees). I'm getting that after I recieve my Flex's.
Old Oct 28, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Where did you hear the EDFC won't fit our cars? My dad has the EDFC with Tein SS's on his RSX and they have just about the same strut clearance to the hood. Anyways, around 1600 would be closer for the tein flex's, and that setup would be DOPE.
Matteo
Oct 25, 2015 05:46 AM
lowriding619
Bolt-on Engine Performance
20
Oct 27, 2003 09:17 PM
CivicLX620
Ohio
Jul 18, 2002 06:49 PM
HCCriminal
May 23, 2002 02:27 PM
CivicLX620
Feb 1, 2002 06:47 PM
