DIY!! AC power for your civic ooOooOOooo
Old Oct 23, 2002
stackz's Avatar
stackz is an unknown quantity at this point
I did a few searches and couldn't find anything like it on here so I'm just curious if anyone is interested in a DIY on how to put an AC power plug into your car and make it look factory. I got the idea from a friend who got the idea after seeing a new pontiac vibe. I've already used it when building my sub box in my car...heh, used my own car to power the saw and I've used it for tailgating to power my 19" tv [IMG]i/expressions/demon.gif[/IMG]
anyway here's a picture of what it looks like in my friend's car and we've got enough pics to write up a DIY with pics too but I don't want to go through the trouble if nobody is interested. yes, his car is a mustang but I've done it in my 98 civic ex in the area where my old factory cd player was...I've got a s2000 starter, an air/fuel ratio gauge, nitrous switches (not plumbed yet) and now I've got a plug LoL!!!!
-stackz
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] inverter15.jpg (16 Kb)
Old Oct 23, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
good job....looks clean
Old Oct 23, 2002
stackz's Avatar
ok also apparently I'm a picture idiot and the pic is an attachment...someone let me know how to actually get the picture to pop up in the forum description for when I write the DIY heh.
-stackz
Old Oct 23, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
Get the url for the image. In this case http://www.7thgencivic.com/old_attachments/inverter15%2Ejpg
click the above the smilies and paste the url into the box. click ok and then post. For a bunch of pictures, just attach them all and post the message, then edit the message and make all of your attached files into pictures
Old Oct 23, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Where did you stick the invertor? Those things get HOT! I'd like to know 'cause i have too many wires when my GF uses her laptop.
Old Oct 23, 2002
stackz's Avatar
it's under the driver's seat and it's a 350 watt power inverter...it hides under their nicely along with my factory head unit (for my keyless...98 ex)...
-stackz
Old Oct 23, 2002
Rider's Avatar
Rider is an unknown quantity at this point
Hey i'm interested in having this DIY dude!!
Good job in the mustang it looks clean!
God idea!!
Eric
Old Oct 23, 2002
stackz's Avatar
yes!! it was a god!! idea hehe....ok someone finally said they are literally interested in the DIY so I will work on getting it completed in the next two to three days as long as interest is still there. Also, just remember to adapt it properly to your civic as it will be for my friend's mustang (the pics...I don't have a digital camera of my own when I did it) though I will offer the commentary of what I did differently than he did. plus remember you can pic any place you want for the outlet...hell even the trunk or the glovebox or on the backseat for when you fold it down...just depends on how creative you are....lol
-stackz
Old Oct 24, 2002
Oishi's Avatar
Oishi is an unknown quantity at this point
i hope those switches are for the inverter as well...you wouldn't want it to be on all the time...
Old Oct 24, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
Isnt there a little rectangular cut-out next to the Cigarette / Power-outlet? I assume we can use that cut-out for the Outlet location. However, does anyone know a way to make a little cover for it. Or should I just buy one of the plastic child-proof covers that you buy for the outlets in a house?
Old Oct 24, 2002
stackz's Avatar
Ok, here it is everyone...I hope the pictures show up right haha....
got the idea from seeing a power outlet on a pontiac vibe. Thought it was cool and would be great for my dedicated laptop for the fuel curve program I had on my diablo chip. Here’s how we did it as a guinea pig in my friend’s mustang
Step 1 - Deciding On Power
First you need to decide how much power you're going to need. The inverter I purchased is rated at 150 Watts. Inverters range from 100 Watts to over 1000 Watts. The more watts you want, the more you're going to spend, and the larger the unit will be. I went with the 150 Watt inverter because it was fairly cheap at $40, it was small, which meant it would be easy to find a place to hide it in the car, and it delivered enough power for my needs.
I was planning on buying a DC to AC Inverter to power my laptop and other devices on the road for quite a while. Then seeing the television commercials for the Pontiac Vibe, which comes with an AC plug in the dash, I decided to hardwire the AC inverter and mount the plug in the dash for a factory look.
This chart was on the back of my inverters packaging and gives an idea of how much power is needed for different devices.
Items / power needed:
Cellphone & Camcorder Charger
20 Watts
Laptop Computer / Digital Camera
38-45 Watts
CD Player / Mini Stereo / VCR
50 Watts
Portable Refrigerator / 9” TV
60 Watts
Car Buffer / 13” TV
77 Watts
Dremel Moto Tool
99 Watts
12” Electric Fan / 19” TV
100 Watts
Rotary Power Tool / Finishing Sander
126-176 Watts
Craftsman 3/8” Drill
220 Watts
Jigsaw / 6” Bench Grinder
232-250 Watts
Printer / Computer / Fax
300 Watts
Electric 3/8” Drill
350 Watts
Blender
450 Watts
Sewing Machine
500 Watts
Portable Vacuum
525 Watts
Coffee Machine
600 Watts
Step 2 - Choosing An Inverter
Once you know how much power you need, next you need to find an inverter that is "install friendly." To keep things simple, try to find an inverter that comes apart fairly easily. The one I got was ideal. two screws held a front plate which when removed allowed a back plate to slide right off, giving full access to the wiring. Also, both the AC plugs and the on/off switch were held onto the metal plate by clips from behind. I used these same clips to mount the parts in the car.
Step 3 - Choosing Locations
In my civic I decided to mount it under the driver’s seat so that will be the first thing to remove…if you can’t do that then stop here because you are incompitent haha. In my friend’s mustang we put it in the console in front of the shifter…in my civic (I’ve got a 98 ex) we put it in a custom panel I’ve done up with an air/fuel ratio gauge and misc. switches where my factory cd player used to be. You can practically put it anywhere you’re willing to whittle out to stick the switch as long as you extend the wires enough
Step 4 - Installation
First off, disconnect the battery because you will be dealing with live wires. Your individual application may vary depending on the locations you choose, but the wiring will be the same. Next "dry" fit the inverter in place to be sure there is enough clearance for the compartment to fit back into place.
Now that you're sure everything will fit, it's time to do the wiring. Open the inverter and locate the two wires leading to the plug you will be mounting in the dash. Also locate the two wires which go to the On / Off switch.
Cut the plug wires and extend them as far as you need to reach the mounting location (in my case, next to the cigarette lighter). Cut the On / Off switch wires and extend those as far as you need to reach the mounting location (in my case, inside under the driver’s seat).
It would be a good idea to put everything together and test the inverter to be sure your connections are correct. Also, leave the inverter on for a few minutes and feel the wires and feel the inverter for heat. If the wires feel hot then you may need to use thicker wires to extend the plug and switch.
Now its time to get rid of the cigarette lighter plug and hardwire the inverter. Take apart the cigarette lighter plug and figure out which wire goes to the "center part" and which wire goes to the "side part." This is key because getting these wires mixed up will result in a blown fuse later. (I know from experience) 8-)
I chose to splice into the wires leading to the extra power point because it was next to my mounting location, and it is the same wires the inverter is "supposed" to be plugged into if used out of the box.
The wire colors may vary between different car years. This is how it was in the mustang. If you get the two wires flipped, you will end up burning a fuse located under the hood near the battery. Check your owners manual for the exact fuse. Pull off the plug from the back of the power point. Connect the "center part" wire from the inverter to the purple and brown wire, and connect the "side part" wire from the inverter to the black wire. Here’s the tangled mess now haha.
Put the inverter back together with all your extended wires sticking out of it. Plug wires (white), On / Off switch wires (green) and Power supply wires (black). Frankenstein should sorta look like this…this is of course the part you hide under the driver’s seat.
It's time to mount the plug and On / Off switch. You should check that everything is working at this point before you start cutting your dash up. Then pick a place and start hacking making sure to test fit every now and then so you don’t make the hole too big and make it look all ugly so frankie doesn’t fit right. Once everything is cut out, mount the plug and On / Off switch (another cut hole or if you’ve got an old switch already mounted…I did from a amp on/off switch haha) and put everything back together.
Here’s the finished product….
ok this took forever, please let me know what you guys think about this heh.
-stackz
Old Oct 24, 2002
stackz's Avatar
Oh ya almost forgot...got sidetracked writing that beast up....when I did mine I got a little smarter than him...I just hardwired my inverter straight to the battery so I was sucking on a constant power lead from the cigarette lighter...no it hasn't burned anything up and yes, the inverter on/off switch still works to turn the whole shebang on and off....I included the instructions for wiring to your cig lighter in case that's what you really want to do and are too lazy to get the bigger gauge wire to go through to the battery and can't think of a good way to hide it and all those little things...enjoy...
-stackz
Old Jan 12, 2003
Validus's Avatar
Validus is an unknown quantity at this point
Great job! I'm very impressed and intend to try it out. thanks man
Old Jan 12, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
thanks i needed that. it will solve the whining noise problem i get, since the invertor is mounted under my seat along with my ps2 and signal cables
Old Sep 30, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
good thread!!
nice job
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
SSMatey
Apr 13, 2015 06:09 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
Hwoody77
Nov 6, 2001 06:14 PM
