Help... Can't get oil drain plug out!
Old Oct 11, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
OK.... So I'm under the car with a 1/2" Socket and a 17mm hex driver, and the damn thing just won't come loose. It's only supposed to be at 31 ft-lbs, so It shouldn't be this hard to get it off. Lefty loosey, correct? What is the trick I'm missing?
Old Oct 11, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
counterclockwise to loosen it. use a metal pipe and insert the wrench/driver in the pipe--like an extension. then turn. u can also use this technik in loosening the nuts on the rims
Old Oct 11, 2002
Jap-Euro Fusion
Alright... I'll find something to use as a breaker bar... Thanks.
Old Oct 11, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Yeah my adivce is make sure you're turning the right way - I spent half an hour my first time (a couple moneths ago) only to find out I was twisting it the wrong way. And on top of that, I put so much force onto turning it, that my socket wrench slipped off the bolt and nailed me square in the forehead. I was walking around with a black eye for a week. It really sucked. Anyways, if I recall it's counter-clockwise. But just don't do what I did, and you should be fine.
Peace.
Old Oct 11, 2002
Jap-Euro Fusion
Success!
My car is now running with Mobil 1
Old Oct 11, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Yeah, breaker bar <voice of master Yoda> Pretty simple the law of leverage is
Old Oct 11, 2002
Jap-Euro Fusion
Actually, once I got 2 hands on the socket wrench, I managed to get it loose. That was mostly because I couldn't find a bar or rod properly sized for the task, and I didn't want to bang it with a rubber mallet for fear of cracking the oil pan. All it took was a little muscle...
Old Oct 12, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
<==has fram suredrain.....works wonders...its well worth $12....
Old Oct 12, 2002
VTEC01's Avatar
VTEC01 is an unknown quantity at this point
All I got to say is use a lil muscle its not that hard c'mon now Just wanted to put my info
Old Oct 12, 2002
anybody have any oil change horror stories?
i had to use a 3ft breaker bar to get my oil drain plug out that an oil change place had overtightened and rounded the edges off of...
Old Oct 12, 2002
Jap-Euro Fusion
Quote
[hr]Originally posted by: 4drcivic2k1
i had to use a 3ft breaker bar to get my oil drain plug out that an oil change place had overtightened and rounded the edges off of...[hr]
No, but I just broke the battery tie down bolt. Sheared it clean off. It wasn't even tight either, it just broke. Oh well, thank goodness for tungsten carbide drill bits and self tapping bolts. I'm back in business.
Old Oct 13, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Ha! I have a story... A tech put thread locker on the oil drain plug for some crazy reason and the next time my buddy decided to change the oil. He busted that bolt right off. $hitttty... Took it back to the place and they replaced it for free. Dang - threadlocker!!! WTF
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
markp94
Apr 30, 2015 09:19 PM
silverdevil
20
Jun 2, 2007 04:42 PM
Grey
16
Jan 27, 2002 11:34 PM
