resetting ecu
resetting ecu
is it ok to reset the ecu on an automatic? dont know if i should because i read that the ecu on the auto has set shift points. i added a k&n filter and denso iridium spark plugs. would it make a difference if i reset?
It's perfectly safe to do it - the ECU just needs to have it's memory regarding the air intake revised.... reseting it just sets everything that to a "default" setting for the car. If this was a problem with automatics, then you could never change the battery on the car! Not good
Ask me about your mom.
man, funny note concerning fuses and ecu.
last night i put on a new exhaust, so i wanted to reset it. i left it out for about 10 minutes...but then had supper. I went back outside to move my car and put another one in the garage...i freaked out, cuz it wouldn't start!!! then i started laughing my a$$ off at how stupid I was, cuz I forgot to put the fuse back in.
make sure you put the fuse back in [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Out of curiosity: after you reset the ECU, how long does it take to learn the computer with new components? is it still a tank of gas? or is it just the first few times to redline?
correct me if i'm wrong ........... you have to reset the ecu everytime you install something for your engine???[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
by the way, how do you reset the ecu??[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
The ECU does adjust itself eventually. That is why when some people add something and the check engine light comes on then they drive around a bit, it goes off. It is better if you just disconnect the battery when installing an intake. because of the excess air the engine will have to adjust. You can get away with not resetting it. I didn't reset it for my exhaust and it has been fine, not check engine light. To reset the ECU take the negative cable off the battery for about 10 minutes. Then put it back on. Your radio will reset itself so I hope you guys have your code to get back into it!!!
Quote
[hr]Originally posted by: YS
by the way, how do you reset the ecu??[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
Quote
[hr]Originally posted by: Wantobedoneup
what would happen if you reved your car when reseting your ecu?[hr]
Quote
[hr]Originally posted by: Aetobatus
automatic have 15a fuse just so if any of you wonder as opposed to 7.5a on manual[hr]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
