Alignments? (How often?)
Old Sep 28, 2002
incaexguy's Avatar
incaexguy is an unknown quantity at this point
Hey, just wondering if anyone could help me out here. How often does everyone recomend front end or all wheel alignments? I have 25,000 miles on my '01 EX. After installing 17" wheels with wider tires I noticed my car starting to pull alot? Ive tried different tire pressures but no luck. When I had my tires rotated recently the guy said I might want to get an alignment soon. How often do you guys get alignments. Car is stock height, no drop just 17s. Thanks.
Old Sep 28, 2002
1955's Avatar
if the shouders of the tire is uneven,u might be in need for an alignment,try to swap the front tires from side to side and see if that help.
Old Sep 28, 2002
incaexguy's Avatar
I would try that but my tires have a directional tread patern and that would mean I would have to pay to have the tires swapped from rim to rim and rebalanced. Thanks for the help though.
Old Sep 28, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I had my alignment done maybe 10 months after I had the car and the guy said it was way off....then again, I live in PA where the roads really suck...so if you have nice roads, maybe only once a year...but if you have really crappy roads, you may be looking @ more than once a year...better to pay the money to have it aligned than to lose your investment in wheels/tires due to misalignment...
However, alignment is not always necessary after installing new rims. My tires are like your, directional. So, what I find after I had my car aligned is that they still pull either to the left or right...that is because of the really grippy tread, and depending on the road surface, it could really bite into the pavement. But ad long as your car doesn't pull to either side hard when u brake, u should be in good shape...
Hope this helps...
2Hottie
Old Sep 29, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Go with the lifetime alignment at Firestone...
Definitely a good deal. For the length of time you own the vehicle you can have it aligned as much as you want it aligned. LOok into it...
Old Sep 29, 2002
2Hottie's Avatar
Quote
[hr]Originally posted by: 2001CIVICLX
Definitely a good deal. For the length of time you own the vehicle you can have it aligned as much as you want it aligned. LOok into it...[hr]
Damn, thats a pretty good deal! Wish they had that around here...the most I got was free wheel balancing for the life of the tires...
2Hottie
Old Sep 29, 2002
civicvtec1ps's Avatar
Search and Learn
Quote
[hr]Originally posted by: 2Hottie
Quote
2Hottie[hr]
i should stop by firestone for that..
Old Sep 29, 2002
dragoon's Avatar
sears and NTB (national tire & battery) also offer lifetime alignments. they're about 40 bucks here, i think.
Old Sep 29, 2002
2Hottie's Avatar
Well, I have the lifetime wheel balancing from NTB, but I didn't know they did lifetime alignments...I should look into that next time, thanks for the info...
2Hottie
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
