Motor swap
Old Sep 4, 2002
SIrokai's Avatar
SIrokai is an unknown quantity at this point
Motor swap
I have a 2000 SIR w/ b16aDOCH in it... I wanna do a swap eventually to a nice JDM motor...
Any advice what would fit in there???
I need something more than 160 hp.
J
Old Sep 4, 2002
taz757's Avatar
Keep the B16A and just rebuild it. That's definately the best way to go. New cams and pistons and all that good stuff. Then you tubro that ****.
Old Sep 4, 2002
mohawkboom's Avatar
Well just buy Type R cams and pistons..or swap to a B18C5 ($5k for the engine and swap) and your looking at 190HP at the crank..
Old Sep 4, 2002
dragoon's Avatar
yeah if you have the SiR already, just keep your motor. there's a ton of potential to go well over 160hp
Old Sep 4, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
keep your motor otherwise ur wasting money.
build the internals.
Old Sep 4, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
i'll swap my d17a2 with you
j/k
Old Sep 4, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Quote
[hr]Originally posted by: SIrokai
J[hr]
Vortech supercharger = 100+ HP
Old Sep 4, 2002
Perfectcivic's Avatar
Perfectcivic is an unknown quantity at this point
internals + turbo= insane amounts of hp
Old Sep 4, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
with the si motor you can go NA and break into the high 13's with the car still being streetable (street tires). less expensive than turbo and supercharger plus less wear on the motor than putting nitrous. There is an si that goes to the drag strip and has run a best 1/4 of either 14.1 or 14.2 NA; he has still yet to put in Skunk2 racing stage II camshafts that will definitely land him in the high 13's. once he hits 50k miles, he will get new rods and forged pistons that will raise the factory 10.2:1 to 11.0:1--->he might get a head gasket to raise the ratio a little higher than 11.0:1
that's a great motor to have with lots of potential
Old Sep 4, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: Perfectcivic
internals + turbo= insane amounts of hp[hr]
Yes yes yes!
Old Sep 4, 2002
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
Either JDM Type R or H22. Make sure both have LSD.
Old Sep 4, 2002
NeoMagus's Avatar
For the price of the Type R motor, he could buy the camshafts, LSD and other parts necessary for his B16 and still probably come out to less than the $5k and up they want for the motor.
Old Sep 4, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
Why the hell are you posting this here?
http://www.clubsi.com
Old Sep 4, 2002
Quote
[hr]Originally posted by: silverdevil
Quote
Yes yes yes![hr]
NO, NO, NO...drivability, anyone?
Vortech SC + Nitrous = Reliable, drivable power plus a lil' something extra for special occassions![IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/demon.gif[/IMG][IMG]i/expressions/demon.gif[/IMG][IMG]i/expressions/demon.gif[/IMG]
Old Sep 5, 2002
SIrokai's Avatar
Quote
[hr]Originally posted by: JoeB16
http://www.clubsi.com[hr]
What the hell is the matter w/ u???
just to match your tone.
Old Sep 5, 2002
JoeB16's Avatar
shaadap and answer the question bish! [IMG]i/expressions/demon.gif[/IMG]
Old Sep 5, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
Quote
shaadap and answer the question bish! [IMG]i/expressions/demon.gif[/IMG][hr]
OWN3D!!![IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 5, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
vortech supercharger will be a better bet and cheaper than a motor swap
Old Sep 5, 2002
mohawkboom's Avatar
Tyrpe R pistons and cams, Teg Type R intake manifold, Bigger injectors, Hondata stage 3 programming. Skunk2 Stage 2 cams. and about 5 hours on the Dyno. $3500.. added horsies. about 30, The free up some added power by disconnecting your power steering. The work on reducing the cars weight.
Old Sep 5, 2002
JoeB16's Avatar
"vortech supercharger will be a better bet and cheaper than a motor swap"
this should read:
"a turbo will be a better bet and cheaper then the Vortech SC which makes you buy almost 2K more worth of aftermarket products and spend hours on the dyno to make the claimed power figures"
Old Sep 5, 2002
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
[IMG]i/expressions/laugh2.gif[/IMG] @ everyone recomending the Vortech kit 5k for a supercharger and running 14's lmao
your best bet is either to swap a GSR or ITR block if you wanna stay with a VTEC block and go that route that will give you good gain with ITR or CTR cams
Or you can do the LS VTEC conversion if you wanna get more involved and have some more torque.
As for wanting a JDM swap dont waste your cash just find a block or build your B16.
Or you can build a B16 turbo and run decent times, friend of mine did a B20 block swap on his B16 bottom end is stock cept for the valve reliefs on the pistons were modified for the VTEC cam, injectors, V-AFC and pieced together turbo kit put down 305hp and 211tq at the wheels on 7psi [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
so yea dont buy into the vortech crap because thats just what it is crap.
Old Sep 6, 2002
JoeB16's Avatar
exactly ubernegro!
Old Sep 6, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The Vortech SC produces very little usable power. It's mainly for dyno queens who like to boast about high peak hp.
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
fatih717171
Jul 8, 2015 12:14 AM
prototype
Feb 6, 2002 05:40 PM
