Civic sits uneven
Old Aug 23, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Civic sits uneven
Anybody else's Civic sit uneven after they lowered it? I lowered mine about a month ago and now it sits uneven , the passenger rear sits higher than the driver's rear... the same thing happened to my Integra when I lowered it. Any ideas what it is?
Old Aug 23, 2002
DMX's Avatar
DMX
DMX is an unknown quantity at this point
whoa??? i thought that was just me... yea after i lowered my car it seems as if it stands uneven... dunno why tho
Old Aug 23, 2002
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Does this happens when the drop is too much? How much of a drop do you guys have? Also; could it be the brand? I'm thinking of lowering my car but if it's going to be uneven then I'll defenetly will not do it. The only thing that is hold me right now is that I don't know if I want a worse ride on my car once I lower it, but if I have two things to worry about I'm probably will not drop it.
Old Aug 23, 2002
pheaton's Avatar
A descendant of 2k1civic.com
I've never heard of that. Unless you jacked something up. I know some springs have to snap into place. Might wanna try jacking up your car then setting it down quickly maybe a spring didn't set in right. I've seen lots of lowered Civics though that look sweet. Well. . no. . I take that back. . There was this one on the interstate the other day. . Had to be about a 94' Civic. . It was riding uneven, but the driver was pushing 400 so ya know. . It's to be expected.
Old Aug 23, 2002
Taffy's Avatar
I weigh about 140 so its not me,
I have GoldLine Springs about a 1.5 inch drop ; it's not that low
It's funny because the same exact thing happened when I lowered my integra with RS*R springs by different installers.
Old Aug 23, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
if they are springs, check if they were mounted correctly(notches on the spring perch should align with the spring). If not, you probably have a settled spring, or yes, a blown shock. If your one of your shocks looks the slight bit greasy, consider that to be shock oil. That is what happens when you lower your cars. If you want to do it the right way, you should have bought some aftermarket shocks, like the Koni yellows. They are the only shocks out there that could handle the increased spring stiffness. if you do not get adjustables, then most likely the shocks are set with the same dampening as the stock shocks.
for everyone with the koni yellows, adjust one side to a stiffer setting and the other side to a lower setting. Your car should ride unevenly.
Old Aug 23, 2002
VNlilMAN's Avatar
The Standard One
how many finger gaps do you have on all corners? it might be an installation issue, just take it back to the place you got them installed. they'll probably give you the 'they have to settle in'. goldlines dont need to settle but just wait a bit and take it back if its still like that.
Old Aug 23, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
with me, one day it'll be even and the next day it's not..
spent about 3 weeks trying to level off my car with my B+G coilovers.
oh well.
Old Aug 23, 2002
Vesper's Avatar
Vesper is an unknown quantity at this point
make sure they put the rubber bushings back on in the rear maybe they forgot one on one side. i know alot of people who have that happen to them so check and see if you can hear like a little rattle in the back.
Old Aug 23, 2002
tekgnosis's Avatar
Ask me about your mom.
Quote
[hr]Originally posted by: WildRice
It's funny because the same exact thing happened when I lowered my integra with RS*R springs by different installers.[hr]
I have GoldLine's, and its not that low of a drop...I have a sedan, and the right side sits higher than the left. But, sometimes it seems that its where the car is parked.
even if the ground looks level, it isn't always the case. sometimes they look even, but its usually the right is higher.
BUT..in my case, I did the front right, the front left, the rear right, then the rear left. so the right side was done first in front and back...i probably screwed up the right side!!! dang.
oh well [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
live and learn...tein coilovers, here i come!
Old Aug 23, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Did you blow a strut already. It's gonna sag a little more if a a strut is blown... just a thought...
Old Aug 23, 2002
tekgnosis's Avatar
i know my struts aren't blown...its an even unevenness [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
the finger gap difference is the same for side vs. side on the front and back.
i probably screwed up the install...dang. oh well...springs make a difference though [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
gotta love 'em!
Old Aug 23, 2002
corruptnu2's Avatar
corruptnu2 is an unknown quantity at this point
I now that fastco springs make it so that the drivers side is actually hire than the passengers side is this the same prob u are having maybe its just the company
Old Aug 23, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
mine is a little uneven too. I have goldlines. The drivers side seems to be maybe 1/4 of an inch higher. maybe the gas tank holds more on a certain side therefore weighting down one one side. he11 i dunno.
Old Aug 23, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Happens to stock height cars too. Sometimes my driver side sits a little higher.
Old Aug 24, 2002
Robi's Avatar
Robi is an unknown quantity at this point
i have had my goldlines for probably about 6 months, and mine is still uneven. i posted something about it a long time ago and nobody said anything about it. i thought it was my cars shocks, but now im thinking its the springs cause everybody else on here said goldline too. oh well, later
Runner88
Mar 2, 2023 04:54 PM
mikemc422
Aug 9, 2018 05:41 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
gabrown2
Apr 11, 2015 08:22 PM
jonavin
73
Oct 4, 2004 07:18 PM
