SOHC OR DOHC
Old Aug 21, 2002
zagzig's Avatar
zagzig is an unknown quantity at this point
SOHC OR DOHC
he's a noob question for all you noob haters out there that throw a fit about everything.
whats the better engine for 5-speed tranny's? SOHC DOHC....never took the time to think about it and i don't feel like "searching".
Old Aug 21, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Quote
[hr]Originally posted by: zagzig
whats the better engine for 5-speed tranny's? SOHC DOHC....never took the time to think about it and i don't feel like "searching".[hr]
Such a rude noob. Ppl just ignore this guy.
Old Aug 21, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
edit: nevermind [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Aug 21, 2002
Bartkat's Avatar
You don't feel like searching?
I don't feel like answering.
But here is a clue. 7th gen Civics are SOHC. So why ask?
Old Aug 21, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
First of all I take it you where trying to type [IMG]i/expressions/moon.gif[/IMG] in your sig area;
Secondly, two is always better than one.
P3AC3
Old Aug 21, 2002
ironcow's Avatar
ironcow is on a distinguished road
there are no such things as stupid questions
just stupid noobs that ask questions
IBTL
Old Aug 21, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
but 0 is better than 2. look at the new 7 series from bmw...no throttle body, no cams...
Old Aug 21, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Quote
[hr]Secondly, two is always better than one.[hr]
Not always true. Audi makes some nice SOHC engines. But generally speaking, DOHC engines produce more power than SOHC engines. And what is your definiton of "better"?
Old Aug 21, 2002
civicer's Avatar
civicer is an unknown quantity at this point
Well minus well not waste a thread so heres the answer
SOHC = single over head cam
DOHC = double over head cam
DOHC is better than SOHC because each cylinder has 4 "holes/cams" (whats the correct name?) Two of them is for intake, and two is for the exhaust. This is comprared to SOHC where there is only one hole for intake and one for exhaust. Obviously, because DOHC has more "holes" it can inhale and exhale faster which equal faster acceration etc... V-tec also works a lot better with DOHC than SOHC.
Boy I hope Im right.....is noobie still under my name?
Old Aug 21, 2002
MSoft's Avatar
I've read from a "VTEC explained" article somewhere that DOHC is not necessarily better than SOHC in terms of performance... It all depends on the application of the engine.
Generally speaking, yeah, DOHC usually generate more HP. But also is much less fuel efficient, etc....
Bottom line is, we don't even have much of a SOHC engine. Our engine is VTEC-E which is an economy version of the real SOHC VTEC... Sucks.
Old Aug 21, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]DOHC is better than SOHC because each cylinder has 4 "holes/cams" (whats the correct name?) Two of them is for intake, and two is for the exhaust. This is comprared to SOHC where there is only one hole for intake and one for exhaust. Obviously, because DOHC has more "holes" it can inhale and exhale faster which equal faster acceration etc... [hr]
The Civic engines are 16 valve engines. Which by 2nd grade math.... 16 Valves/4 Cylinders = 4 Valves per Cylinder and it's an SOHC.
Old Aug 22, 2002
IMURMILK's Avatar
I do a body good
IMURMILK is on a distinguished road
Msoft- The only civic with the v-tec E is the HX...shoulda went EX got the straight v-tec
Old Aug 22, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
Quote
[hr]Originally posted by: IMURMILK1
Msoft- The only civic with the v-tec E is the HX...shoulda went EX got the straight v-tec[hr]
yup yup
Old Aug 22, 2002
Bartkat's Avatar
This it the 7th Gen Civic Board
The 7th Gen Civics have SOHC
An engine swap to DOHC is near impossible
So why ask the question when we are pretty much stuck with SOHC?
Old Aug 22, 2002
MSoft's Avatar
Really? My bad. Have always thought it was VTEC-E in the EX. Aha, I do have an EX (Si Canada), haha...
Old Aug 22, 2002
klam's Avatar
klam is an unknown quantity at this point
Quote
[hr]Originally posted by: civicer
Boy I hope Im right.....is noobie still under my name?[hr]
Our cars are SOHC yet we have 16 valves, meaning 4 valves/cylinder. SOHC just means we have one overhead cam to operate the valves. DOHC has two cam shafts, one to operate intake, one exhaust valves. This allows more flexibility since the two cam shafts are independent, and usually DOHC makes more power. Acura TL/CL, Mercedes-Benz use SOHC. Mercedes uses 3 valves/cylinder. Audi uses 5 valves/cylinder.
Old Aug 22, 2002
maxEmus's Avatar
a.k.a incamus
maxEmus is an unknown quantity at this point
no comment!
danace99
Oct 17, 2015 02:51 PM
Amulon
Aug 18, 2015 11:03 AM
jwalkerck1
Aug 17, 2015 10:03 PM
darwin-t
Aug 15, 2015 10:51 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
