Speedometer adjustment
Old Aug 14, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
If I get smaller-than-stock wheels, is there any way I can readjust my speedo/odometer so it reads correctly? I don't really care so much about the speedo, but I don't want the odo to rack up a bunch of miles I didn't actually drive.
Old Aug 14, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Bring it in to the dealers and have them readjust it.
Old Aug 14, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
Quote
[hr]Originally posted by: n00dleboy
Bring it in to the dealers and have them readjust it.[hr]
I thought that costs $$$$$$$$$$ though. Isn't it expensive?
Old Aug 14, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
Just get tires that are close enough to the stock speedometer. Use the easy tire calc to figure it out. Tire Calc!
Old Aug 14, 2002
WD40's Avatar
Quote
[hr]Originally posted by: Ducatti
Just get tires that are close enough to the stock speedometer. Use the easy tire calc to figure it out. Tire Calc![hr]
I'm getting 16" Slipstreams and I don't want to use 55 tires. I like at least 50's for handling reasons.
Old Aug 14, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
I've been curious about that myself... wondering if anybody has had their ECU/speedometer recalibrated so it would read the correct speed if i wanted to get a wheel/tire combination that was shorter than stock.
Old Aug 14, 2002
NAWSguzzler's Avatar
From: Revealing Your Prophecies, Federated States of Micronesia, US
NAWSguzzler is an unknown quantity at this point
How does the speedometer get affected by change in tire size? I "thought" logically [IMG]i/expressions/laugh2.gif[/IMG] it never mattered.
Is my math that bad?! [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Aug 14, 2002
solar's Avatar
solar is an unknown quantity at this point
Quote
[hr]Originally posted by: NAWSguzzler
Is my math that bad?! [IMG]i/expressions/face-icon-small-sad.gif[/IMG][hr]
Yes your math is that bad. Just research wheel size/speedo adjustment, you'll see.
Old Aug 14, 2002
WD40's Avatar
Quote
When the car comes stock from the factory they know what size the wheels/tires are. The car's computer measures how many revolutions the wheel makes in a given ammount of time, and then calculates your speed from that.
If you change the size of the wheel to something smaller than stock, it makes more revolutions in that time period. The computer doesn't know that you changed wheels, so it still applies the same math to a smaller wheel, and therefore registers a faster speed.
Back on topic: Is the general consensus that the dealer should be able to recalibrate it? Is there anywhere else that can do it? Maybe something through AAA?
Old Aug 14, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
From what I know the Odo doesn't use that input to calculate how far you have traveled. I don't know how but I guess your speedo can be off by whatever amount but your odo will allways be accurate.
Be carefull driving if you don't recalibrate the spedo. As I'm sure you are aware, you will have a slower indicated speed so you might think your doing 55 when in fact you are closer to 62 or something.
Old Aug 14, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
yeah the odo works off of the speedo input. if your going 60mph it clicks off a mile every one minute...etc etc..
Old Aug 14, 2002
WD40's Avatar
Quote
[hr]Originally posted by: silverdevil
Be carefull driving if you don't recalibrate the spedo. As I'm sure you are aware, you will have a slower indicated speed so you might think your doing 55 when in fact you are closer to 62 or something.[hr]
If I were putting larger wheels on I'd have that problem. My problem will be the reverse, my aftermarket wheels will be smaller and so my speedo will show a faster speed than what I'm really travelling.
Old Aug 14, 2002
You are right. I was just checking to see if you were paying attention
Old Aug 14, 2002
BlackSI's Avatar
so far looks like nobody here has had their 01+ civic recalibrated for shorter wheel/tire combo
Crazygrlinak
Oct 8, 2015 05:06 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
