Speedometer adjustment
If I get smaller-than-stock wheels, is there any way I can readjust my speedo/odometer so it reads correctly? I don't really care so much about the speedo, but I don't want the odo to rack up a bunch of miles I didn't actually drive.
Just get tires that are close enough to the stock speedometer. Use the easy tire calc to figure it out. Tire Calc!
Quote
[hr]Originally posted by: Ducatti
Just get tires that are close enough to the stock speedometer. Use the easy tire calc to figure it out. Tire Calc![hr]
I've been curious about that myself... wondering if anybody has had their ECU/speedometer recalibrated so it would read the correct speed if i wanted to get a wheel/tire combination that was shorter than stock.
From: Revealing Your Prophecies, Federated States of Micronesia, US
How does the speedometer get affected by change in tire size? I "thought" logically [IMG]i/expressions/laugh2.gif[/IMG] it never mattered.
Is my math that bad?! [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Quote
[hr]Originally posted by: NAWSguzzler
Is my math that bad?! [IMG]i/expressions/face-icon-small-sad.gif[/IMG][hr]
Quote
If you change the size of the wheel to something smaller than stock, it makes more revolutions in that time period. The computer doesn't know that you changed wheels, so it still applies the same math to a smaller wheel, and therefore registers a faster speed.
Back on topic: Is the general consensus that the dealer should be able to recalibrate it? Is there anywhere else that can do it? Maybe something through AAA?
From what I know the Odo doesn't use that input to calculate how far you have traveled. I don't know how but I guess your speedo can be off by whatever amount but your odo will allways be accurate.
Be carefull driving if you don't recalibrate the spedo. As I'm sure you are aware, you will have a slower indicated speed so you might think your doing 55 when in fact you are closer to 62 or something.
Quote
[hr]Originally posted by: silverdevil
Be carefull driving if you don't recalibrate the spedo. As I'm sure you are aware, you will have a slower indicated speed so you might think your doing 55 when in fact you are closer to 62 or something.[hr]
Crazygrlinak
Oct 8, 2015 05:06 PM
260000milesgoal
Sep 25, 2015 07:41 PM
