Securing Sub Enclosure
Old Aug 6, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
I have a single 12 inch sub with my amp screwed to the back of the box. I am having a heck of a time securing the box. Any Ideas would be greatly appreciated. Thanks
Old Aug 6, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
Velcro, screws, L brackets.
Old Aug 7, 2002
mohawkboom's Avatar
well the floor is 1/4" HDF..you can use machine screws with nuts under the trunk board and use an L bracket to hold it down..
Old Aug 7, 2002
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: mohawkboom
well the floor is 1/4" HDF..you can use machine screws with nuts under the trunk board and use an L bracket to hold it down..[hr]
your lucky then, i got compressed particle whatever junk for my floor. same stuff i used as a kid to do puzzles on.
Old Aug 7, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
where is it in your trunk anyways. before you secure it yor should move it around and see where you get the best response and then if its not too much in the way secure it there. and because of vibration its not always the best idea to have your amp mounted to the box itself
Old Aug 8, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: WhiteRabbit
Quote
your lucky then, i got compressed particle whatever junk for my floor. same stuff i used as a kid to do puzzles on.[hr]
I rebuilt my floor with 1/2" MDF not.. used 4 common hinges and made in 2 parts so I can get to my spare [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 8, 2002
oh. from they way you worded it, i thought yours came stock that way.
Old Aug 8, 2002
mohawkboom's Avatar
no stock is the 1/4" HDF..if you use machine screws..nuts and washers it can hold down an L Bracket
Old Aug 8, 2002
Quote
no stock is the 1/4" HDF..if you use machine screws..nuts and washers it can hold down an L Bracket[hr]
Old Aug 9, 2002
Yukonart's Avatar
Yukonart will become famous soon enough
Hey, Mowhawkboom. . . . did you just take your panel out, trace the shape onto the 1/2" MDF, and take a jigsaw to it?
Hmmm. . . my dad's got some 1/2 plywood sitting around. Could probably bum some off him and do the same. LOVE the hinged-panel idea. I was just starting to think of how I might configure my trunk once I get a sub in there!
A decent piano hinge might work well, too. Hmmm. . .got the gears in my head turning, now! Thanks!
Old Aug 11, 2002
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
Yeah thats a really good idea adding hinges...wonder why I didnt think of that awhile ago. Want to make a custom amp mount underneath the board too with plexiglass and all that too, hopefully there is decent room between the board and the spare tire.
Old Aug 11, 2002
plenty of space for a single small amp, but i wanted to fit more than 2 devices under there, so i needed to raise the floor 3 inches using L brackets and 1x3's.
but just about any 4 channel amp will fit under there, without raising the floor (or raising it much, some amps are taller than others [IMG]i/expressions/face-icon-small-wink.gif[/IMG] )
h4ldol
Apr 24, 2017 08:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
junkyardguy
Sep 2, 2015 06:07 PM
