Low volume from sub?
Old Jul 20, 2002
klam's Avatar
klam is an unknown quantity at this point
Ok, so I hooked up a sub to my car tonight. Using speaker-level inputs directly to a mono amp.
My problem is that when I spliced into either left or right rear speaker signal alone, it sounded fine. But when I splice into both, the subwoofer becomes inaudible? I have checked +/- on the splice. Am I suppose to splice into rear left and rear right, and + and - if it is a mono amp (4 splices)?
Old Jul 20, 2002
mohawkboom's Avatar
You might be shorting the speaker wires where you spliced it and your cancelling your output signal.. Swap the wires from one side over...should be left+ to right + ..left- to right -.
Cheers
Mohawk
Old Jul 21, 2002
klam's Avatar
Actually I figured it out today. It wasn't the left/right swap, but positive/negative on one side. I always thought brighter color wire = positive, but i was wrong... haha
Once I swapped the positive and negative, it was working.
MrOldskool
Aug 18, 2015 09:58 AM
CraigW
Aug 18, 2015 07:06 AM
jwalkerck1
Aug 17, 2015 10:03 PM
honda.lioness
Aug 6, 2015 11:58 AM
alxz310
Jul 30, 2015 12:18 PM
