intake question
Old Jul 19, 2002
louie1234's Avatar
louie1234 is an unknown quantity at this point
intake question
did anyones check engine light come on when they installed their intake? if so what did you do to turn it off and what was wrong with it. please help.
thanks.
Old Jul 19, 2002
dragoon's Avatar
check your airflow sensor (or whatever it's called) that plugs into your intake. mine didn't do a thing!
Old Jul 20, 2002
speedracersong's Avatar
reset the ecu.
Old Jul 20, 2002
civictunerfool01's Avatar
civictunerfool01 is an unknown quantity at this point
hey, you need to plug the air sensor in and if it still is going on after that, give it a day or two, and the light will go off. Its sort of like the car is getting used to having alot more air than before. It should turn off when it "adapts" itself. if not go somewhere!!
Old Jul 21, 2002
johnride's Avatar
johnride is an unknown quantity at this point
Mine never came on after I installed the intake. Just make sure you put the sensor in and if still goes off just unplug your battery for like 10-15minutes and it will reset it self.
Old Jul 22, 2002
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
your intake sensor wasn't all the way the first time you started the car....just make sure its in and unplug the battery and re plug it
Old Jul 23, 2002
XScarAudio's Avatar
XScarAudio is an unknown quantity at this point
the same thing can happen when you do anything messingh with the air/fuel ratio or the sensors for exhaust etc. it is basically the car telling you something changed while it was running. it will remember this unless you tell it not to. just d/c the neg terminal on the battery, grab a beer, watch a southpark episode, then go re attatch the neg terminal, start the car, and you should be fine
carid
Nov 7, 2015 01:46 AM
Farticle69
Aug 6, 2015 08:02 PM
spyder13
Jul 31, 2015 06:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
